Quick engine code Q
Old Jan 29, 2008 | 09:13 PM
NuYorka103185's Avatar
Default Quick engine code Q
Will a 2000 1.8t block with engine code ATW work with my automatic, the block was pulled from manaul
Old Jan 29, 2008 | 10:15 PM
cincyTT's Avatar
I'm make believe
Default RE: Quick engine code Q
no, the cranks are differnt. You need a tip engine. that is unless you want to swap cranks.
Old Jan 31, 2008 | 04:24 PM
how difficult would it be to swap cranks? I am having trouble finding a tip engine for my car
Old Jan 31, 2008 | 04:27 PM
cincyTT's Avatar
I'm make believe
Not hard for a good engine builder. But then you would be in for about another $500+ in labor and maybe another $200 for a used crank.
Old Jan 31, 2008 | 04:47 PM
EFF that i'll just be a little more patient
Old Jan 31, 2008 | 05:08 PM
cincyTT's Avatar
I'm make believe
sorry man, your luck is as bad as mine
Old Jan 31, 2008 | 05:16 PM
yeah, oh hey my engine code shouel be AEB right? 2000 1.8t Auto/tip Quattro
Old Jan 31, 2008 | 05:32 PM
cincyTT's Avatar
I'm make believe
99.5 is the last of the AEB. You should have a ATW. A AEB engine would also work
Old Jan 31, 2008 | 05:47 PM
what difference would there be?
Old Jan 31, 2008 | 06:09 PM
cincyTT's Avatar
I'm make believe
just the ecu and tb. The atw has dbw and the aeb has dbc.
