quick FMIC quest.
Old Nov 17, 2007 | 01:18 PM
oettinger1919's Avatar
SoCal Crew Member
Default quick FMIC quest.
Do you need to be running a chip for a Front mount Intercooler to work properly. whats is neccessary?
Old Nov 17, 2007 | 01:30 PM
PandaXpress's Avatar
Default RE: quick FMIC quest.
having a FMIC on stock programmin is kinda pointless
and u will lose boost also
Old Nov 17, 2007 | 01:31 PM
SoCal Crew Member
thanks thats what i needed to know
Old Nov 17, 2007 | 01:40 PM
FASTER's Avatar
Tech Slut
running a front mount is only needed when you have heatsoak issues, ie. bigger turbo, live somewhere very hot... otherwise its fine to retain stock side mount.
Old Nov 17, 2007 | 01:44 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: FasterA4ThanUrs
stock sidemounts heatsoak with just a chip, let alone with a BT.
Old Nov 17, 2007 | 01:46 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: PandaXpress
Thats because the people install the ebay kit that uses to large of piping and to large of a ic for theko3/4 turbo. Bigger isnt always better.
Old Nov 17, 2007 | 02:09 PM
FASTER's Avatar
Tech Slut
ORIGINAL: cincyTT
yea they can heatsoak with just a stock setup, but not so much if you live in colder climate, thats why i said if you live somewhere hot, if you beat your car you will reap the effects. im speaking in terms of necessity, there is not much of a reason for a fmic if you live in average to cold temps and your not drivin it like you stole it.
Old Nov 17, 2007 | 06:59 PM
Beer Mod's Avatar
Chances are if you are thinking about a FMIC you are the kind of person who will also want a chip.
The 1-2psi drop will be made up (power wise) by the colder denser air.
Old Nov 17, 2007 | 07:02 PM
FASTER's Avatar
Tech Slut
pick the right setup and the drop in pressure will be minimal if at all
Old Nov 17, 2007 | 08:31 PM
SoCal Crew Member
im getting chipped by REVO in a couple weeks and i wanted to throw on a FMIC to do something different but wanted to make sure it wouldnt be overkill and end up slowing me down. I live in Socal so it gets pretty warm and that intake manifoldgets ridiculously hot no matter what time of the year it is...
