quick question
Old Apr 16, 2007 | 03:43 AM
a4BRZLowrider's Avatar
Default quick question
does the springs and shocks from a 01 s4 fit on a 97 a4?
Old Apr 16, 2007 | 03:55 AM
sean1.8t's Avatar
Default RE: quick question
will they fit? yes... will they fit and look/function right? no
but is the a4 quattro? V6?
Old Apr 16, 2007 | 04:18 AM
thanks...yes quattro and v6....why would it not function right or look right
Old Apr 16, 2007 | 04:28 AM
sean1.8t's Avatar
well i thought you would be 1.8t. and possible fwd.. but it should work out pretty well actually.. reason being that your car is very much like an S4, weight wise anyways. so the springs should look and perform well..
but a fwd 1.8t would look a bit off with s4 springs. cause it's almost 300lbs difference in the front and rear so it would sit high. if that makes sense to ya
Old Apr 16, 2007 | 04:43 AM
pyropenguin's Avatar
Yeah it'll be fine. A couple guys on here have tried to put S4 springs/shocks on a 1.8t and the front end was higher than stock, and the rear was lowered.
I dont think the S4 rear springs would even fit on the fwd A4.
Old Apr 16, 2007 | 07:07 PM
thanks guys...
Old Apr 16, 2007 | 07:20 PM
fobyulous's Avatar
yeh you should be good to go, i ordered some b5 s4 coilovers for my car i have a 96 2.8Q. as long as you are a B5 2.8Q you are fine with ride height and it all matching up
jmcdowel
B7 Models
Jan 6, 2014 05:48 PM
grimace132
Nov 21, 2012 08:10 PM
DustanS
Jun 10, 2011 10:45 PM
khj677turbo
Dec 23, 2007 06:00 PM
ThePapaCMan
Apr 11, 2007 02:26 AM
