Radiator fluid
Old Jan 4, 2005 | 10:16 PM
Chill72's Avatar
Member
Default Radiator fluid
Is coolant in 03 A4 1.8T supposed to be brown? I've never seen anything like that before, I hope that's standard. If not then I'm getting some oil mixed with coolant
Old Jan 4, 2005 | 10:23 PM
clconversion's Avatar
Default RE: Radiator fluid
um yea the coolant should be pink but if its mixed with oil it will turn into a Milkshake colour
Old Jan 4, 2005 | 10:28 PM
Doose's Avatar
Yeah, not good. What does your oil look like?
Old Jan 4, 2005 | 10:31 PM
Jestnomen's Avatar
6th Gear
Take a sampe of your coolant, sometimes the coolant expansion tank turns brownish. The coolant should be a vibrant pink color. If your coolant is indeed brown, stop driving the car and have it looked at.
Old Jan 4, 2005 | 10:32 PM
Chill72's Avatar
Member
Oil looks dark brown like it needs to be replaced
Old Jan 4, 2005 | 10:33 PM
Chill72's Avatar
Member
Also the car isin't overheating or anything
Old Jan 4, 2005 | 10:36 PM
Jestnomen's Avatar
6th Gear
Any type of white stuff on the inside of the fill cap? Also take a flashlight and shine it down into the oil fill. Look for white foam or slime.
Old Jan 4, 2005 | 10:37 PM
Chill72's Avatar
Member
Got ya...I'll do that
Old Jan 4, 2005 | 10:40 PM
Jestnomen's Avatar
6th Gear
Also, how long has this been your car?? The previous owner may have mixed green coolant with red, which turns the mixture brownish. If that is not the case, there are three issues that could cause this...blown head gasket (worst), blown oil cooler (bad), or yellowed/browned expansion tank (best!).
Old Jan 4, 2005 | 10:47 PM
Chill72's Avatar
Member
I've had this car for about a month and got it from a dealer.
With a blown gasket I would surley notice some unusual noises and/or fluctuations in fluid levels right?
