radiator leak, i think
Old May 10, 2006 | 08:08 PM
ecksman's Avatar
Default radiator leak, i think
on the way to work i noticeed a little steam coming from in between the hood and fenders i pull over, no fluid sprayed anywhere like i expected. just a little steam coming from in between the radiator and motor(2.8 12v),the only thing i noticed was the motor side of the radiator was a little wet only in a small spot.cant figure out where it is coming from. it never overheated and the coolant light never came so forced myself to get it home, when home i popped the hood to see i could where it was coming from but to no avail. that spot that the radiator was wet was dry as a whistle. any suggsetions on what to do next, u guys alwways come up with some good advise
Old May 10, 2006 | 10:05 PM
Jestnomen's Avatar
6th Gear
Default RE: radiator leak, i think
I'd just monitor the coolant level as frequent as possible for a few weeks.
Old May 10, 2006 | 10:11 PM
onepoint8tee's Avatar
Thats a tuffy.
Old May 11, 2006 | 02:02 AM
ecksman's Avatar
its definetly leaking steam if not coolant, very slowly cause isee a very small difference in coolant level. i was thinking of just driving it around some more and hope the leak becomes more evident, man i really dont need this right now i just got to paintball, amd money burns in my hand, well it already did
Old May 11, 2006 | 02:05 AM
Could be a small crack that will eventually get bigger.. Has the engine ever overheated to your knowledge?
Old May 11, 2006 | 02:28 AM
ecksman's Avatar
the coolant gauge would always go one or two notches over the middle when idling for a long time on a warmer day but never smoked or smelled or went over one or two notches over the middle
Old May 11, 2006 | 02:35 AM
Well id start pricing up radiators if i were you, to be safe..
Old May 11, 2006 | 02:38 AM
tip5's Avatar
Might not be that check your waterpump.
Old May 11, 2006 | 02:51 AM
ORIGINAL: tip5
yeah it may not be a bad radiator, but in my experience, steam and a "wet spot" on the radiator signifies a cracked core....
Old May 11, 2006 | 05:15 AM
BadLuckAudi's Avatar
yea +1 from my experiences thats right
ORIGINAL: onepoint8tee
ORIGINAL: tip5
