Rattle on deceleration, Wastegate?
Subscribe
Nov 15, 2006 | 03:39 PM
I have a rattle from the front of the car on deceleration. I read that someone had a rattle like this because his wastegate had gone bad. does this sound like it could be my problem?
Reply
Nov 15, 2006 | 03:50 PM
RE: Rattle on deceleration, Wastegate?
Make a hook out of a coat hanger. Tug on the actuator rod, it should feel solid. If you can reproduce the same noise you hear during decel it most likley is the problem.
Reply
Nov 15, 2006 | 03:53 PM
also check the heat covers on the exhaust
Reply
Nov 15, 2006 | 04:00 PM
I have checked the heat sheilds, but I will try the hanger thing when I get home. thanks.
Reply
Nov 19, 2006 | 01:37 PM
It could also be your diverter valve. Tt's had lots of problems with dv's rattling on decell or acell. No real way to test it thou.
Reply
Nov 19, 2006 | 04:09 PM
could be the sign of a bad wastegate or dead cat that has the cells rattling around
Reply
Nov 19, 2006 | 04:15 PM
Wouldn't the post cat O2 sensor pick up a bad cat? I have pretty much the same problem. Thanks.
Reply
Nov 19, 2006 | 07:21 PM
well if the cats just starting to go bad then no the post cat 02 wont pick it up right away, if it does you will get a CEL for cat ineffiency
Reply
Nov 19, 2006 | 08:54 PM
Yeah I'm 97% sure my cats are going bad. The rattling is REALLY bad and the heat shields are fine.
Reply
Nov 20, 2006 | 04:36 AM
He is what my brother and I did...
With the hood open, turn the throttle plate by hand. Take a metal rod about 1/4 inches in diameter and touch it against the turbo. If the turbo is making the sound, you will clearly hear the sound coming up through the rod. You will need to put your ear up against the rod to hear the sound.
Another method is to use some hose as a makeshift stethoscope. We tried this first, but the hose was made of silicone and it melted.
I referr to the sound as "the rattlesnake." It sounds like some marbles being rattled in a coffee can.
Reply
