yea just take it to the auto store and pick one up
Site Moderator/Ninja
Quote:
ORIGINAL: kextyn
WHAAAA? [:@] really? I guess the same goes for B5 S4s as well??? Cuz I only have 1 that lights up on drivers side..ORIGINAL: kextyn
Quote:
ORIGINAL: d_maniac
i only have one rear fog light working right now its the left side...i just brought the car. I took out the bulb assembly and saw the bubl that needed to be changed
B5 A4's have ONE (single, uno) rear fog light on the rear left.
ORIGINAL: d_maniac
edit: wow - its true... & this whole time I thought i was procrastinating
changing out a bad bulb [:-]
yea is so when your cruising on the Autobahn and someone passes you they dont **** up and clip your drivers side
Quote:
ORIGINAL: d_maniac
no one knows the bulb size number??
On my 2002 A4 1.8T the numbers areORIGINAL: d_maniac
1156 for the all of the big ONE FILAMENT BULBS and 1157 fo the one TWO FILAMENT BULB
The smaller one has the follwing info on the side:
17171NARVARS(or could very well be a 5, hard to tell)W12V5WEI(boxed in) B4
to fit the same size bulb in the right side, you will need to dremel the hole out a little larger
RE: rear fog lights question
I've got a DIY writeup on how to drill a hole and have two rear fog lights. Let me know and I'll email it to anyone interested. It's simple, all you need is a drill and a wide drillbit. I've got pics and all!
If you want to change out the bulb in your single rear fog light, just remove the cover from the inside of the trunk and unclip it from it's housing...that simple. Remove the old bulb, bring it in to Napa or Autozone etc. and it'll all be taken care of for a couple bucks.
LampyB.
LampyB.
ps. it's a european deal with only having one fog light. american cars don't even have a single rear fog light. in europe they use it as a distance indicator, and not for looks (like me)...haha
LampyB.
LampyB.
is a diy really nessecary to do it.. hell i did it before i knew it was a mod (just thought the tailight had been replace and it was a effed up housing)
Quote:
ORIGINAL: i3uddha
HAHA, you just now figured that out? roflORIGINAL: i3uddha
