Rear Sway Bar
Old Oct 9, 2006 | 03:33 PM
JettaRedII's Avatar
Default Rear Sway Bar
Is the rear sway bar for the A4 with sports suspension the same as the one on the S4?
Old Oct 9, 2006 | 04:05 PM
evoic's Avatar
Default RE: Rear Sway Bar
No.
The rear sway sizes are:
Standard -16mm
S-Line and Sport Suspension -18mm
S4 - 20mm
RS4 - 22mm
All are drop-in replacements for each other, meaning if you want to go up or down a size, there is no welding involved.
The bushings fit in the same brackets and you can order all through Audi at a relatively low price.
Old Oct 9, 2006 | 06:14 PM
PandaXpress's Avatar
i think hes talkin about the B5 rear sway and the sport and s4 are the same
Old Oct 9, 2006 | 08:44 PM
evoic's Avatar
I live exclusively in my B7 world and I frequently make this mistake.
My apologies if this info above is absolutely useless to you, JettaRedII.
And to pour salt in the wound, I don't know the answer to your original question.
Old Oct 9, 2006 | 10:17 PM
TheJazz7's Avatar
Yah, Panda's right (per usual)
B5 S4 rear sway bar = B5 Sport Pkg rear sway bar (16mm each)
Old Oct 9, 2006 | 10:31 PM
wood_e's Avatar
no its 19mm...
Old Oct 10, 2006 | 09:39 AM
JettaRedII's Avatar
Thanks, guys. I should have been clearer. I am referring to the B5. Since the "sport-type" sway bar is under $100, I was hoping for a cheap upgrade. But since I have the sport suspension, I'm going to have to go with something aftermarket.
Old Oct 10, 2006 | 12:18 PM
TheJazz7's Avatar
ORIGINAL: wood_e
no its 19mm...
I really think the B5 Sport Pkg sway bar is 16mm...but whatever, I've been wrong before.
JettaRed, my Neuspeed bar set me back a little over $200 and I've got no complaints. Pretty easy install and a noticable difference.
Old Oct 10, 2006 | 01:57 PM
JettaRedII's Avatar
ORIGINAL: TheJazz7
I will get under the car and measure the bar’s diameter. $200 for the Neuspeed bar is pretty good. Where’d you get it for that price?
smittylube
Oct 17, 2013 10:34 PM
villacorta32
May 13, 2012 06:13 PM
germantech
Dec 24, 2007 02:29 AM
B5luver
Dec 18, 2007 12:42 AM
ronin23
Dec 6, 2005 05:03 PM
