Rear wheel bearing OUT, don't want to go to STEALERSHIP!
Old Mar 29, 2007 | 01:09 AM
aschmit's Avatar
Default Rear wheel bearing OUT, don't want to go to STEALERSHIP!
how do I go about replacing my rear wheel bearings without going through the stealership????? They want to charge me $700 to replace both my rear wheel bearings because there is a so called "tool" that only they have. What is this "tool" and how do I go about getting it? All the mechanics in my area (MD) can't fix it because of this. PLEASE HELP!! I've had 2 mechanics look over my car and both have told me they can't help me because they can't get the hub off.
Old Mar 29, 2007 | 02:03 AM
fobyulous's Avatar
Default RE: Rear wheel bearing OUT, don't want to go to STEALERSHIP!
what year car? quattro or non quattro?
Old Mar 29, 2007 | 02:33 AM
skunkoncrunk's Avatar
Did you take it to some Euro mechanics? They should definatly be able to work on your car.
Old Mar 29, 2007 | 02:40 AM
SAudi's Avatar
Lucky you, they were charging me $500 each wheel, take it to NTB, cost me only 175 labor and 65 for a meyle original bearing. special tool my @$$, theyre just gonna hammer it out and use a press to get the new one in
Old Mar 29, 2007 | 09:33 AM
david9999's Avatar
My garage charged me 100 dollars or labor and the part was about 65 from the net.
Old Mar 29, 2007 | 12:58 PM
oh1a4's Avatar
theres no special tool. hub shark and hydraulic press. make sure whoever you take it to keeps your alignment by marking the washer!
Old Mar 29, 2007 | 01:18 PM
JohnnyBravoA4's Avatar
you need a 14 mm allen to take the rear hub and off.. and a press.. not to hard.. to me 1.5 hours
Old Mar 29, 2007 | 01:22 PM
FASTER's Avatar
Tech Slut
yea u need that monster allen on an impact tool. easy as ****
Old Mar 29, 2007 | 01:25 PM
oh1a4's Avatar
youre not going to get the torque right for the collar bolt with impact. its a stretch bolt so i would be careful with it, make sure you always replace.
Old Apr 1, 2007 | 11:05 PM
aschmit's Avatar
thanks guys, I am taking it to get worked on this week. The quote I got was from a Audi dealer in Baltimore becuase everyone I talked to around my area didn't have equipment to do the job. They charged $90 an hour labor and said it took 6 hrs to do both wheels! So I'll just tell the mechanic about that 14 mm allen key and be done with it. I hear you have to set the suspension too? Has anyone ever heard anything about that?Can't a local mechanic just do it with the 14 mm allen wrench? instead of spending $700 at a dealership?
Thanks
