Rear Wheel Bearing Tool
Old Mar 16, 2007 | 02:42 PM
BraMas's Avatar
Default Rear Wheel Bearing Tool
So I go to replace the rear wheel bearings on the car. And I find out they use a 15MM Allen head bolt on the bolt that holds the hub on. Does any one know where I can find the right wrench. I have searched everywhere in my area and the Internet and the biggest anyone has is a 10mm. I can't believe something so simple is stopping me[:@]
Car is a 98 A4 Quattro
Old Mar 16, 2007 | 03:09 PM
techbod's Avatar
Default RE: Rear Wheel Bearing Tool
that's a big Allan key mate try some shops or the garages might be able to help/rent/lend you one
Old Mar 16, 2007 | 03:20 PM
onepoint8tee's Avatar
A hardware store. It most likely wont be the allen key type, but a socket set... Like this:
I looked at 3 different auto parts stores in their tool section, and i finally found a hardware store (mostly industrial tools) that carried them. I would imagine that Sears hardware would carry them too, did you try there?
Old Mar 16, 2007 | 03:24 PM
JohnnyBravoA4's Avatar
its not 15mm its 14mm.. so dont get the wrong size.. and good luck trying to find it I ended up making one.. took a 14mm bolt and weilded it on a socket.. no one had one.. I just did mine..
Old Mar 16, 2007 | 03:29 PM
You should really buy a allen socket set though cuz there are several locations where you need 10-15mm sizes. I like bravos idea though, crafty and free.
Old Mar 16, 2007 | 03:43 PM
well all the kits i found at local places only went up to 10mm.. Sears, Home depot, Lowles, and a few hardwear stores, Nappa, pep boys, car quest.. no one stocked that size.. but they could all get it. so I just said f-it wored fine.. weilded it to an impact socket worked perfect..
Old Mar 16, 2007 | 04:24 PM
bluesnapper's Avatar
For DIY wheel bearing don't you need a press as well. Just thought I would bring it up. There has been no mention of it in this thread.
Old Mar 16, 2007 | 04:32 PM
akielb's Avatar
He's doin the rear not the front
Old Mar 16, 2007 | 04:44 PM
vjmaudi's Avatar
I just got my rear wheel bearing replaced. You do need a press to get the bearing out.
Old Mar 16, 2007 | 04:45 PM
BraMas's Avatar
Yes you need to press the bearing in. I already have the tools rented to do that. I also made a tool like mentioned above but it looks like the previous owner had tried to do some work there and messed up the hole a little so I couldn't get a good bite. But there is 13mm hole in there also but I was hoping to use the right tool on that one because most bolts that have a 13mm head on them are not the strongest bolts and I'm scared I'll just brake it in half.
