Recode for warning lamps
Old Dec 25, 2005 | 01:50 PM
Diavan's Avatar
Default Recode for warning lamps
I just replaced my brake pads with no sensors.
Found the following procedure on Rosstec to disable BrakePad wear sensor. Thought it would be a good idea to vag it, instead of shorting the wires.
Apparently it was never active (code 02244). But I'm still getting the brake pads symbol on my display. Moreover, the code shows that 'Seat Belt Warning is Active', but I never get any prompt for that while driving either.
Has any one else setup their seatbelt/brakepad warnings thru vagcom.
I could be doing something wrong, or the method could be for different years of A4.
Thanks.
A4 1.8T 2001 Quattro (Tip)
Recode for warning lamps:
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock
Look at the fourth digit in the coding (Cylinders):
4 - 4-cylinder
6 - 6-cylinder
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
Old Dec 29, 2005 | 06:53 PM
Diavan's Avatar
Default RE: Recode for warning lamps
Has any one enabled/disabled their seatbelt/brakepad warnings thru vagcom. (A4 2001 1.8t)
Old Dec 29, 2005 | 06:58 PM
onepoint8tee's Avatar
I dunno about the brakes but ill be finding out shortly when i replace my rears... As for the seatbelt thing, I never have a seatbelt light when im not wearing it.. Im wondering if there even is a seatbelt light, i should check the owners manual i guess.
Old Dec 29, 2005 | 07:00 PM
Diavan's Avatar
I don't get seatbelt warning either.
I saw the seatbelt warning lamp coding in VagCom though. So I was wondering if anyone has enabled & disabled it either.
Old Dec 29, 2005 | 07:02 PM
ORIGINAL: Diavan
Now that you mention it, I remember seeing the seatbelt light when i scan my ecu for codes but only then.. Good call... Whats up with that?
MetalMan
Jul 6, 2012 07:11 PM
b5audi1.8t
Feb 25, 2009 07:25 AM
jabbawoki
Nov 17, 2008 05:31 PM
beng
May 31, 2008 08:13 PM
mizzike2555
May 21, 2008 11:51 AM
