Red Lights on the moonroof control panel?
Old May 17, 2007 | 12:43 AM
BigMikeLV's Avatar
Default Red Lights on the moonroof control panel?
What are these two red lights on my moon roof control panel? Just forward of the map lights. Only on when the headlights are on.
2007 A4 CVT
Old May 17, 2007 | 12:50 AM
S_R_N83's Avatar
Default RE: Red Lights on the moonroof control panel?
Ambient lighting...to set the mood
Old May 17, 2007 | 05:58 AM
david9999's Avatar
Small LEDs that shine on the dash at night to help locate the controls
Old May 17, 2007 | 11:59 AM
beast a4's Avatar
lights for your girlfrend to put her hand under and wonder wat there for same with the lights up in ur door handles
Old May 17, 2007 | 03:57 PM
DavidL A4's Avatar
Laser beams used to detect intruders
Old May 17, 2007 | 05:07 PM
A4philly's Avatar
ORIGINAL: DavidL A4
HAHAHAHA....Why couldn't I think of anyrthing like that
Old May 17, 2007 | 06:46 PM
Pablo_Ottawa's Avatar
No no no no. You're all wrong. They're German made brainwash beams that they are using to take over the world... or heat lamps
Old May 17, 2007 | 08:22 PM
CLX's Avatar
CLX
Zombie Defense Force
Nah, you're all wrong! They are infrared heaters to warm the cabin air, making the car lighter so the massive 3200lbs of weight doesn't seem so heavy.
Actually, if you have a manual trans and you put the shifter in neutral, the little diagram on the shifter reflects it hardcore awsome.
Old May 18, 2007 | 03:48 AM
BigMikeLV's Avatar
ORIGINAL: david9999
I'll go with that answer...
Old May 18, 2007 | 04:52 AM
Flarika's Avatar
They help you see your hands as they approach the control panel for improved coordination/efficiency.
I did not know that an A4 weighs 3200 lbs. And I've read my owner's manual about 5 times already!! (actually HOPING to discover something I didn't know about my car..., which I have done a few times, but I'm pretty sure I've covered it all by now). But somehow, I neither learned nor inquired about the vehicle weight...
Hmmmnnnn.....
