removing Automatic shifter
Old Aug 31, 2006 | 07:55 PM
budnfrida's Avatar
Default removing Automatic shifter
Does ne1 know how to get this part out? It is the Automatic shifter on a 1996 A4 2.8
[IMG]local://upfiles/20259/3A7BBAB0044D42A0ACFFE54C97C4F870.jpg[/IMG]
Old Sep 1, 2006 | 03:47 AM
budnfrida's Avatar
Default RE: removing Automatic shifter
come on guys i thought this was the place for help.
Old Sep 1, 2006 | 04:17 AM
PandaXpress's Avatar
sorry not alot of us have the older model autos and have removed them
Old Sep 1, 2006 | 07:20 PM
JohnnyBravoA4's Avatar
best bet would be to look up some local used auto parts stores that might be a good start..
Old Sep 1, 2006 | 09:54 PM
budnfrida's Avatar
I have the part already from the dealer i just need to know what the easiest way to install it. It looks like i have to go from the bottem but not sure.
Old Sep 2, 2006 | 12:06 AM
try running a search on the vw vortex forum someone on thier with a 99 passat took it apart and took pics i beleave or try audiworld sorry i cant help never done it
Old Sep 3, 2006 | 12:24 AM
budnfrida's Avatar
i tryed searching budt didnt find anything do you remenber or know with post it was?
Old Sep 3, 2006 | 02:26 PM
david9999's Avatar
Fig. 2 Shift mechanism housing, removing and installing
- Remove bottom shielding plate and catalytic converter.
- Disconnect selector lever cable from shift mechanism housing.
- Before installing, secure rubber housing -A- to shift mechanism housing.
- Tighten nut - 9 Nm
Note: Rubber housing -A- must seal shift mechanism housing to chassis (sealing lip -B-).
Do not rout any cables between chassis and mounting bracket.
This is for Non tip, as you didn't mention tiptronic in your message
[IMG]local://upfiles/1947/F5BB160A1D0E42DD910A9516A59EF787.gif[/IMG]
[IMG]local://upfiles/1947/3B2CC757650640BFBA0FBACC32E3960A.gif[/IMG]
pbrules10
Dec 14, 2011 07:53 AM
balla915
Dec 28, 2009 05:47 PM
shady927
Apr 15, 2008 05:19 PM
arb
Aug 12, 2006 10:24 PM
psuaudi
Aug 25, 2005 02:47 PM
