Removing Factory Cellphone Antenna - any tips?
Old Jul 6, 2007 | 09:44 PM
MrFlippant's Avatar
Default Removing Factory Cellphone Antenna - any tips?
My '97 A4 has the factory-installed cellphone kit, which I obviously don't use; so before I go prying the antenna off my rear window, has anyone done this before? If so, can you offer any tips? To look at it, I'm guessing a little (careful)elbow grease behind a flat screwdriver, followed by a healthy dose of Goo-Gone ought to do it. Thanks in advance...
Old Jul 6, 2007 | 10:46 PM
auditech79's Avatar
Default RE: Removing Factory Cellphone Antenna - any tips?
Why would you wanna take it off, you don't wanna scrape into the rear window with a screwdriver or anything like that cause you can strip the rear window heater lines off the glass. Then you got no rear window defroster.
Old Jul 7, 2007 | 12:29 AM
MrFlippant's Avatar
Well, since I don't need it I'd rather get it off there so my roof line is more streamlined. I just think it looks goofy. Is there perhaps something better than a screwdriver that you could suggest? And aren't the heater lines on the inside? The inside element of the antenna is not an issue; the adhesive on that has already degraded enough that it fell off on its own, so I'll just cut the wire where it comes out of the head liner and toss it, and then clean off the remaining adhesive.
Old Jul 7, 2007 | 12:31 AM
Belligerenceā„¢'s Avatar
I can't see there being a problem with prying it off with a screwdriver. to do a nice job you might try using a fresh, brand new razor blade. that'll take most of the adhesive off by itself, and the goo gone will finish it off.
Nevalite
May 4, 2013 09:06 PM
Xarpolis
Apr 15, 2010 02:05 AM
pete7
Oct 13, 2008 03:29 PM
pete7
Sep 25, 2008 10:20 PM
B5nightrider
Jun 8, 2005 06:34 PM
