removing fog lights *updated* please help
hello everyone. i posted this a while on audiworld, but the responses i got werent that great. i was wondering if anyone could tell me how to remove my stock foglights on a 2000 a4. is it a simple unplug the light or does it require some work? thanks in advance
update: ok so i followed what doose said, and getting the drivers side light off was easy, but when i tried to take off the passenger side fog light grill, it wouldnt come off. anyone know how to take it off? i need to know by monday. thanks in advance!!
If you're trying to replace the lamps this site has directions, make sure you don't replace it with a higher wattage bulb you'll fry your wiring. If you're trying to replace the whole fixture good luck.
http://www.audiworld.com/tech/
The higher wattage bulbs doesn't fry anything. I've been running 100 watt bulbs in mine for six months. It's still 12 volts. I haven't read the tech article, but it's pretty easy to get off. The part of the lower grill that surrounds the fog lamp snaps off and then the whole fixture comes right out. On a 2000 with the conventional halogen fixtures, the lamps they take are the same as the head lamp and hight beam, H7's. HTH.
Yoon, they should both come off without too much trouble. The grills are both snap in. Do you have a bulb out or something? I'll tell you, with those 100 watt bulbe in there I light up the entire road, that's for sure. They are still focused beams but I don't out drive the low beams anymore.
nize
Jun 21, 2013 01:16 PM
