Replace Auto Shift Knob??
Old May 1, 2006 | 06:55 PM
jhawk1977's Avatar
Default Replace Auto Shift ****??
Has anyone done this? Got a DIY? I can't even get the shifter to come off? What's the trick?
Old May 1, 2006 | 07:03 PM
BadLuckAudi's Avatar
Default RE: Replace Auto Shift ****??
the trick is this...... you should have bought a manual Id check for set screws around the bottom, mine has a little collar thing that comes up and screws on and there are little screws under that, but mins a manual i dotn know for sure about an auto
Old May 1, 2006 | 07:19 PM
jhawk1977's Avatar
Can I get some credit for the Tip??
Old May 1, 2006 | 07:30 PM
onepoint8tee's Avatar
ORIGINAL: jhawk1977
No, Ive tried.. PM Brrman about it, he has done it. There is a a plastic (chrome plated) ring on the bottom of the **** that slides down and there is a screw there i think... Not positive... I personaly like the stock ****..
Old May 1, 2006 | 07:33 PM
brrman's Avatar
lots of info here if you search on "auto shift ****"...
I remember posting this one a while back
LINKY
What **** you put on depends on if you get the SupremePowerParts adapter - which allows you to pull the **** upwards to engage it, as opposed to having to push a thumb button. If you get the SPP mod then you can add virtually any **** you want.
And don't worry about the digs you get about the tip... I love my tip.
Old May 1, 2006 | 08:39 PM
well i was sorta right with the little thing going down and the screw
Old May 1, 2006 | 09:21 PM
brrman's Avatar
well, you were completely wrong there... LOL [8D]
Old May 2, 2006 | 05:00 AM
AHB900's Avatar
you could get the TIP MOD i forgot where i saw it but its like you can put any manual shifter **** on it and the way it works is if u wanna throw it into gear you pull up on the shifter and move it into gear. i think itwas like 60 bucks? if i find it ill link you.
Old May 2, 2006 | 05:03 AM
brrman's Avatar
ORIGINAL: AHB900
LOL - I guess you didn't read much of this thread... Look three replies up from yours. The SPP mod is what you are refering to I believe.
Old May 2, 2006 | 05:07 AM
AHB900's Avatar
http://www.supremepowerparts.com/app...8/_SPP_Tip_Mod there you go bro.
