Replacing Control Arms!!!!
Old Jun 18, 2007 | 05:11 PM
Audi_Skydiver's Avatar
Default Replacing Control Arms!!!!
Ok, so I have a sucky situation right now! My car needs new Tie-Rod Ends AND control arms!!! Almost all the bushings on the control arms are cracked and worn. I am probably going to be getting the kit from ECS Tuning that has everything I need. Now my question is, how hard is it to replace that stuff yourself? And what special tools will I need? I do NOT want to have to spend another $400 for labor (yes I called around my town to different shops.) I have found the DIY that explains it and I m pretty sure I would be able to do it, but I am just wondering how hard it really is. Thanks!
Josh
Old Jun 18, 2007 | 05:16 PM
onepoint8tee's Avatar
Default RE: Replacing Control Arms!!!!
Its not hard, just time consuming and you gotta have the tools. Im pretty sure www.getcoolparts.com has better prices for the control arms/tie rods. Of course you canget them REAL cheap on Ebay, but the brands they have are very unknown as is thequality.
I stand corrected- ECS has them for $10 less for the Meyle brand compared to getcoolparts. Free shipping too! Thats an ECS rarity!!!
Old Jun 18, 2007 | 05:23 PM
headshok2002's Avatar
Avoid Meyle... I've heard too many bad things lately. One company (can't remember who) sells MOOG control arms... They were much more money (700?) but moog stuff has a lifetime warranty... so I'd absolutely go with them, if I could do it again. (I bought a Febi Bilsten kit months ago, and just installed it last week).
The install was a PITA... Uppers can be hell because of the devil bolt (pinch bolt), and the lowers are hell because of the inside bolts... You'll need two 18mm wrenches (ratchet won't fit), and a 16mm wrench and a 16mm socket for the c-links (or two 16mm wrenches).
It wasn't THAT bad... but it WAS a pain in the *** for sure. The first side I did one day... the other side I did the next day, in about half the time I think. You also have to loosen one big bolt that goes to the subframe, kind of pry the subframe down with a prybar, in order to get the bolts out of the lower rear control arms (on both sides). I also had to free some metal lines (fuel/brake?) from their clips to move them out of the way... because the bolt was hitting them as I tried to remove it.
It's doable for sure... but I'd have beer next time. I was cursing a lot, under there...
Old Jun 18, 2007 | 05:28 PM
Interesting... One says easy the other says PITA. Lets get a third opinion. LOL
Josh
Old Jun 18, 2007 | 05:35 PM
Ive heard nothing but good things about Meyle, and their products just seem to be so beefy. I have heard the pinch bolt can be a PITA, but other than that, its just down to having a good tool collection and time. I dont have personal experience with them, so Im sure headshok's story is more credible, but for me,there is a difference between "hard" and "PITA."
I dont think I ever said "easy" though.
Hows this:
Its not hard, its just a PITA.
Old Jun 18, 2007 | 05:39 PM
Yeah, it is certainly not hard, as in complicated... Those 6 bolts though, (the 2 pinch bolts [devil bolts] and the 4 inside bolts on the 4 lower control arms will be a bastard, though. The lowers fought me the whole bloody way, until the nut fell off. I was sweating like a ****, my arms were aching... it was good times.
And I was hearing about Meyle kits needing replacement after a little more than a year. I actually sold my Meyle kit before installing it, and went with the Febi kit instead.
Old Jun 18, 2007 | 05:40 PM
auditech79's Avatar
Everything is easy with a big enough air hammer
Old Jun 18, 2007 | 05:45 PM
ORIGINAL: headshok2002
I havent heard that, got a link??
Old Jun 18, 2007 | 06:02 PM
Yeah I would like to see that also. If thats the case I don't want to get those.
Josh
Old Jun 18, 2007 | 06:13 PM
techbod's Avatar
whats the big deal here a simple job,
remove the bolt first then use a splitter
http://images.google.com/imgres?imgu...%3Den%26sa%3DG
