Replacing O2 Sensors Univeral or OEM?
Old Jun 25, 2007 | 11:26 AM
tfische12's Avatar
Default Replacing O2 Sensors Univeral or OEM?
I am replacing the original 2 precat O2 sensors on my 2000 2.8Q with 135k. I am doing this to hopefully smooth engine idle (motor mounts were replaced) and increase mpg. I am leaning to the bosch universal to save some $$ over OEM. Has anyone had any problems with this or should I use a differnt O2 sensor. I don't want to use the really cheap 30$ ones for obvious reasons. Thanks for your help.
Old Jun 25, 2007 | 12:26 PM
cincyTT's Avatar
I'm make believe
Default RE: Replacing O2 Sensors Univeral or OEM?
the only difference is the high cost one has a clip on the end so you dont have to connect the lines. Get the cheaper one, its the same sensor and even comes with supplies to connect the wires.
Old Jun 26, 2007 | 11:31 AM
rbrtech's Avatar
they both are the same bosch sensor. I always recomend oem but for the price diffrence universal works
Old Jun 26, 2007 | 11:37 AM
techbod's Avatar
Default RE: Replacing O2 Sensors Universal or OEM?
cost based and yes they are the same without the plug connector in most cases but easily solved
Old Jun 26, 2007 | 04:19 PM
dafrazi's Avatar
Buy OEM. The ECU is sensitive to the voltage readings off the O2 sensor. A bad connection or bad solder job and you will be getting bad O2 readings. Easier to just buy OEM and avoid the connection problem.
Old Jun 26, 2007 | 04:31 PM
cincyTT's Avatar
I'm make believe
you would have to really screw up a solder job for it not to work. plus its a simple job.
Old Jun 26, 2007 | 05:03 PM
Trey25's Avatar
any DIY articles regarding this???
Old Jun 27, 2007 | 01:59 PM
dafrazi's Avatar
ORIGINAL: cincyTT
You would think so but I have first hand experience. I solder pretty well too.
Old Jun 27, 2007 | 02:18 PM
tfische12's Avatar
I am going to get the bosch universal no soldering required just a pair of wire strippers.
http://www.automedicsupply.com/showp...p;sensor=15733
I will order them from oxygensensor.com. cheaper. Unless anyone knows where to get them cheaper than that.
Thanks for everyones help.[sm=thanx.gif]
k5bensinger
Oct 12, 2009 03:04 PM
Q7 owner
Audi Q7
May 29, 2009 01:03 PM
madridlover
May 6, 2008 09:27 PM
speed_racer_801
May 20, 2007 06:02 PM
north5995
May 15, 2006 03:21 PM
