Replacing vac lines
Old Jan 17, 2006 | 02:12 AM
onepoint8tee's Avatar
Default Replacing vac lines
Im going to replace my vac lines soon. Are the vac lines ONLY the 3.5mm ones? Or are there larger diamater hoses too? I know the boost hoses are bigger ones like that come out of the turbo, IC and DV and stuff? But to do what i need to do, should about 5 or 6ft of 3.5mm silicon hoses be enough? Are there any other sizes ill need? I cant seem to find 3.5mm hoses and good clamps anywhere other than ecs tuning. Thanks. Also, if anyone has a picture of the locations of all the hoses that should be replaced that would be freakin awesome. I'll probably just replace them as I find them.
Old Jan 17, 2006 | 02:17 AM
trailboss's Avatar
Default RE: Replacing vac lines
I ordered 10ft and had about 5-6ft left over, never know when your gonna need it.
Old Jan 17, 2006 | 02:27 AM
ORIGINAL: trailboss
SO what is there, like 6 or so vac lines to replace of the 3.5mm?
Old Jan 17, 2006 | 02:30 AM
david9999's Avatar
Have fun.
[IMG]local://upfiles/1947/0AEC18AB5FCE4CB489896B7784A90844.gif[/IMG]
Old Jan 17, 2006 | 02:31 AM
ORIGINAL: david9999
Have fun.
Why... Is it a pita? Doesnt seem like it would be too much.
Well from the looks of that diagram it may be.. Thanks.
Old Jan 17, 2006 | 02:32 AM
trailboss's Avatar
Ones i can think of off hand that are that size, the one that goes to the top of the DV from the intake mani, the FPR to intake mani, all the n75 valve hoses, there are more. Someone has a diagram im sure, i just replaced everything i saw.
Old Jan 17, 2006 | 02:35 AM
ORIGINAL: trailboss
Thanks.. And did you order any other size hoses ?
Old Jan 17, 2006 | 02:40 AM
trailboss's Avatar
No, i did a boost leak test before I did the lines and found 2 when i replaced my lines. I just replaced the ones and a few other that were that size.
Old Jan 17, 2006 | 02:44 AM
ORIGINAL: trailboss
How many miles did you have when you did that?
Old Jan 17, 2006 | 02:45 AM
trailboss's Avatar
~65k
