Retorque clyinder heads
Old Jun 24, 2015 | 05:16 AM
Conrod2's Avatar
Default Retorque clyinder heads
I have a a4 3ltr pertol 2004 (asn) engine with a slight water loss and white smoke on start up but the smoke clears carried out a gas sniff test on the coolant system which indicated a head gasket leak would a clyinder head retorque help this problem?
Old Jun 26, 2015 | 11:09 AM
doctorul_doc's Avatar
I think that will indicate a blown head gasket. Did you try a compression test on each cylinder?
Just re-torque would not help at all. You must find the root problem, not to try to avoid it. You can get engine damage if not act in time.
R-bo
Dec 25, 2010 04:05 PM
drev500@aol.com
Aug 3, 2008 04:33 PM
cvacc411
Dec 9, 2006 12:36 AM
rbrtech
Nov 11, 2006 08:38 PM
