rip off?!?
Old Aug 31, 2005 | 07:27 PM
Fieldy's Avatar
Default RE: rip off?!?
yep,, those warranties are just sophisticated scams.
why don't you get the 710N valve from a tt as your DV for like $35 bux i believe.
Old Sep 1, 2005 | 12:58 PM
north5995's Avatar
What is the 710 good for up to... 250HP? Can it be used with a K04?
Old Sep 1, 2005 | 01:48 PM
JettaRedII's Avatar
ORIGINAL: north5995
Do you know what a DV is? It has nothing to do with horsepower, but with boost. The 710N will hold 20 psi easily. The stock DV is a 710; the "N" version is different.
Old Sep 1, 2005 | 02:03 PM
clconversion's Avatar
if you are going to use a K04 i would upgrade to a forge 007 the 710N can only hold up to 18psi
Old Sep 1, 2005 | 02:49 PM
north5995's Avatar
Yeah I knew it had nothing to do with HP.... had to do with how much boost the K04 turbo upgrade would create. I should have rephrased my question. I was wondering if it could hold the boost.
Thanks for the response.
Old Sep 1, 2005 | 04:37 PM
if you are just getting the regular E05 software for your K04 then you will see about 21-22psi
Old Sep 1, 2005 | 05:08 PM
IamSputnik's Avatar
Go to Audiworld.com and check around the Canadian Forum there are a couple of Manitobans on there.
