which rotors to replace in brake vibration?
Old May 6, 2007 | 08:42 AM
fritz's Avatar
Default which rotors to replace in brake vibration?
alright, which ones, the rears or fronts? I get the vibration when i brake or should i just do the whole thing?
Also, on the new rotors that i buy, will likely buy it from getcoolparts.com, is it just a simpel replacment -> take out old rotor, replace with new one or is there some secondary operation that i need to do as well?
thanks,
Fritz
Old May 6, 2007 | 11:11 AM
acetrebo's Avatar
Default RE: which rotors to replace in brake vibration?
Replace the ones that are vibrating.
Are you sure that's your problem though? Vibration could also be suspension related. Does it do it everytime you brake, from any speed?
Do you feel it in the pedal, or just feel the car shaking? Suspension/tires/brakes could cause vibration.
Give a little more info, maybe we can help figure it out. Likely its probably the front brakes, rather than the rear, as they get used/worn a lot faster than the rears.
If they do need replaced, its a good excuse to upgrade to some cross-drilleds instead of stock.
Old May 6, 2007 | 11:18 AM
ironman's Avatar
Might as well jsut do it all around cross drilled rotors and nice low dust pads. And if that doesnt do it, new suspension.
Old May 6, 2007 | 02:04 PM
sdsteez's Avatar
the rotors are simple to replace. the only thing that takes a while to figure out your first time is the pressure clip that holds the brake pad. you haaaaave to force it in. i would say start with the front but if you have the billllz might as well do all around. fyi: cheap drilled and/or slotted rotors are crazyy loud and annoying when you go from like 80 to 0 say from the freeway to the offramp. its a horrible noise its almost embarresssing when you got ppl in the car.
Old May 6, 2007 | 05:55 PM
fritz's Avatar
so i was looking at the rotors on getcoolparts.com, would those be considered teh cheap ones?
Old May 7, 2007 | 03:09 AM
acetrebo's Avatar
Forthree hun you can get all four from ecs tuning.
169 for the fronts, 129 for the rears.
Add 2 sets of pads and put them on yourself, you'll be set.
Old May 7, 2007 | 03:23 AM
fritz's Avatar
so im going for the upgraded rotors, do i need to upgrade the type of pads i use or calipers or is it just a simple swap?
to answer the earlier question, the car shakes when i apply the brakes, not termendously but some feedback is felt.
Old May 7, 2007 | 05:28 AM
turboAUDI77's Avatar
ORIGINAL: fritz
if the car shakes when you apply the brakes you might have warped rotors.
FishEye
Jul 10, 2019 12:17 AM
milo55041
Oct 26, 2007 05:32 PM
milo55041
Oct 8, 2007 09:19 PM
