running cables for amplifier
sooo, i'm running (or attempting to run) some cables for my amplifier to power my subs and i've been having an awfully hard time getting the positive lead through the firewall. anybody had any experience triumphing over the big bad firewall? heeeeelp
there are rubber gaskets all along the firewall. poke a hole on one, and run it through. if you want, go to www.goapr.com. go to audi, and find the installation instructions for their boost guage. it will show you how to run a hsoe through the firewall and into the drivers side. it should be the same for a wire. good luck
ORIGINAL: new2me
I will be using the gromit that is in the middle of the firewall. Its just to the left of the ecu.
i dont know about the clutch cable you might end-up with some binding issues. all the gromits i have dont have wires in them already. Take a pic of the firewall so we can see what's going on there.
well i am pretty sure right under or to the passenger side of the ecu box there is a rubber piece you can poke through and get a wire through it, its pretty simple just look around for it
