Rusty rotors
Old Nov 24, 2004 | 12:51 PM
dudley doright's Avatar
Default Rusty rotors
I changed the rear rotors of my A4 over the weekend and I did not changed the pads. This morning I noticed that there are some traces of rust where it should normally be shiny (where the pads meet the rotor). What do you think the problem is?
Old Nov 24, 2004 | 01:02 PM
CRAZYHAWK's Avatar
Default RE: Rusty rotors
If the car isn't driven over time, this can occur.
Old Nov 24, 2004 | 01:10 PM
brrman's Avatar
totally normal - however whenever you change your rotors you should always change pads.
PaulA4's Avatar
Happens with all brake discs or rotors as you guys call them, they are after all just steel.
Old Nov 24, 2004 | 01:16 PM
99a4audi's Avatar
ya no worries, my rotors were rusty also bc before i bought my car it sat outside in the rain and **** at the dealership, u mgiht hear some squeek while breaking but it should wear off soon, or at least mine squeeked
Old Nov 24, 2004 | 02:03 PM
Jestnomen's Avatar
6th Gear
Rotors can rust practically overnight in humid conditions. You can buy rotors that are treated (cadmium plated) so they don't rust as easily. Eventually though, they all rust.
Old Nov 24, 2004 | 02:16 PM
clconversion's Avatar
just drive it will go away after a while
Old Nov 25, 2004 | 11:35 AM
It was still there after driving for a while. I will try to check the seating of the pads.
Old Nov 25, 2004 | 12:14 PM
david9999's Avatar
If it is rusty where your pads are supposed to press, either your pads are not seated correctly, your calipers are binding, or your pads are shot. Did you try to bed your pads to the new rotors?
You should always change pads with new rotors anyway.
Old Nov 25, 2004 | 02:05 PM
The pads are still a lot of meat on it. Do you know what the thickness should be for a new pad vs. worn?
