scanner trouble
Old Sep 2, 2006 | 07:29 PM
audibri02's Avatar
Member
Default scanner trouble
I can't seem to find a scanner to read my car. I thought a vag would do it but it doesn't. so my question is has any body else encountered this problem. It doesen't seem like the obdii port is working. If anyone has info that would be great. thanks
Old Sep 2, 2006 | 08:05 PM
audi_pa's Avatar
Default RE: scanner trouble
year/model
Old Sep 2, 2006 | 08:41 PM
Jeff's Avatar
Zombie Defense Force
a vag should work. thats what audi uses. i would check the vag you used to make sure it working
Old Sep 2, 2006 | 09:08 PM
audibri02's Avatar
Member
sorry its an a4 2002 1.8t
Old Sep 2, 2006 | 09:30 PM
Jeff's Avatar
ORIGINAL: audibri02
that shouldnt matter. if its that new then my guess is a bad scanner or the wrong connection
Old Sep 3, 2006 | 12:31 PM
audibri02's Avatar
Member
The only plug I know of is the one under the drivers side in the back left. I seriously think that something is going wrong with the connector. I have three different scanners and none of them work on the car. I know the scanners work because I tried them all on my brothers jetta. I don't know what the problem is. I have an appointment with the dealer on wednesday and there supposed to try to fix it but I thing there just going to say they looked at it and say they can't fix it or it will cost alot of money to fix or since I only got a 30 day warrenty with the car that won't be covered.[:@]
Old Sep 3, 2006 | 12:53 PM
techbod's Avatar
it could be you haven't set the correct COMS port up on your laptop
Old Sep 3, 2006 | 01:06 PM
CRAZYHAWK's Avatar
This should be under a longer warranty that includes all pollution equipment.
Old Sep 3, 2006 | 02:12 PM
david9999's Avatar
The connector was moved in 1999 to the left side of the lower front dash
Old Sep 3, 2006 | 02:39 PM
audi_pa's Avatar
thank you...the year was important because the connector was moved in 99'. wanted to make sure he wasn't trying to put it into the cigarette outlet. lol
check your settings for the vag are you using a usb port or db9 connector
did you activate you vag?
are you getting a light on the vag connector
to get my vag to work i had to download the software, go to my car do a comms test and come back in to get online to verify the vag. and then it worked.
