Scary Problem
Old Mar 9, 2005 | 03:10 PM
Sebass's Avatar
Default Scary Problem
So yesterday morning I woke up and went to get breakfast for the girlfriend...Got in the car and backed out. Dropped her into Drive only to see the engine rumble a little bit and would not drive forward when the gas pedal was depressed. Turned the car off and back on and drove fine all day with no problems. NO CEL is on. Haven't run a VAG yet as I figured maybe it was user error...
However, just went to go get some drinks for our lunch...same exact thing happened. Turned the car off and problem disappeared.
I had this checked out before I purchased it and it got a clean bill of health.
2002 A4 Quattro Tiptronic 1.8T
What do I do?
Also, just curious if the engine is supposed to heat up as fast as it does. Granted I come from about a 100 HP 4 banger...but boy does this car just warm up quicker than most I have seen...
Old Mar 9, 2005 | 05:24 PM
Jestnomen's Avatar
6th Gear
Default RE: Scary Problem
I'm guessing you are still under warranty right?
Old Mar 9, 2005 | 05:31 PM
Sebass's Avatar
No sir...about 4,000 miles out of warranty...
Old Mar 9, 2005 | 05:50 PM
CRAZYHAWK's Avatar
Check the transmission fluid. This should be done by a qualified shop. PITA
Old Mar 9, 2005 | 05:56 PM
Sebass's Avatar
I wanted to add that it is not that the car wouldn't drive forward it just went extremely slow at about 1000-1500 RPM's....and literally if I turned it off and back on it was like what just happened was a complete fluke!
Old Mar 9, 2005 | 08:46 PM
Sebass's Avatar
CEL just came on as I was coming home...I'll run VAG and let you guys know what I find...I am praying that it is something not so $$$$ intensive!
Old Mar 9, 2005 | 10:00 PM
Sebass's Avatar
VAG-COM didn't come up with anything form the transmission so I am not so scared anymore...although this is what I found:
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT G 0001
Coding: 0016751
Shop #: WSC 63351
2 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 002 - Lower Limit Exceeded
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04277
Shop #: WSC 06435
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 46: Central Conv.
Controller: 8E0 959 433 T
Component: Komfortgerát T5B 0617
Coding: 11788
Shop #: WSC 63351
1 Fault Found:
01332 - Door Control Module: Passenger Side (J387)
80-10 - Single-Wire Operation - Intermittent
I don't have my Bentley here at my ladies so if anyone can give me an idea of what I am looking at I would appreciate it. Estimate on the cost if you have an idea would be great too!
Old Mar 9, 2005 | 10:05 PM
Jestnomen's Avatar
6th Gear
16795 - Secondary Air Injection System: Incorrect Flow Detected <------Vacuum Leak
Old Mar 9, 2005 | 10:06 PM
CheckMyVitals's Avatar
Coding: 04277
Shop #: WSC 06435
1 Fault Found:
01119 - Gear Recognition Signal <--------Pricey
Old Mar 9, 2005 | 11:36 PM
Sebass's Avatar
Thanks for the responses...I guess I am gonna have to find a good mechanic in the area that has experience with Audi's and have them run the tests to see where the codes are arising from...from the Bentley manual I know I cannot do this myself...this sucks...I got a clean bill of health and have had this car for 4 days!
