Secondary air pump
Old Mar 9, 2006 | 05:04 AM
dab_master's Avatar
Default Secondary air pump
when i start my car when the car is cold there is rattling coming from what i believe is the secondary air pump. once the rpms drop to its normal idle the sound goes away. when i was in an accident a year ago this peice was replaced. what would cause this to happen? what does it the secondary air pump do? if thats not what it is can somone tell me what it is the car is a 2000 1.8tQ
Dustin
[IMG]local://upfiles/5497/38F7A6897BA44979BABC6E4450CE35ED.jpg[/IMG]
Old Mar 9, 2006 | 02:52 PM
onepoint8tee's Avatar
Default RE: Secondary air pump
The secondary air pump helps with emissions when you start your car up i think..
Old Mar 9, 2006 | 02:55 PM
rbrtech's Avatar
What you are ponting at is the combination valve for the AIR system and you are correct it is for emissions during startup. Though the rattiling noise may not be that unless it is lose. If the combination valve goes bad you will recieve a cel with code p0411. Check for loose componets such as your air pump in its metal bracket.
Old Mar 9, 2006 | 08:24 PM
mjvss21's Avatar
yea the secondary air pump pumps fresh air to the cat during cold starts to help it heat up faster and so it can work faster. what a worthless thing that is tossing me a CEL light and they are so damn expensive.
Old Mar 9, 2006 | 10:48 PM
socalaudi's Avatar
I have the same rattling noise sometimes during startup. I dont know what it is but I've also been told that its the secondary air pump.
Old Mar 10, 2006 | 04:25 PM
brrman's Avatar
The secondary air pump is under the front of the car on the passenger side, just behind the bumper. Purely an emissions device.
if you only get the rattling when the pump is on (for about 30 secs after starting the car cold) then the pump is either dying or it is loose in its housing (3 heavy bolts hold it to its bracket).
A healthy pump should barely be heard. Mine sounded like a jet turbine for a while - that lasted for nearly a year, then it started sounding like it was grinding gravel, so I figured I'd replace it before it exploded...
I just recently replaced it myself.
Old Mar 10, 2006 | 11:50 PM
headshok2002's Avatar
I heard that if the combination valve goes bad... it lets moisture into the SAP, which kills it, too... dealers change them simultaniously, I believe.
boostedboot
Dec 13, 2011 11:10 PM
jeeps5
Sep 22, 2011 06:01 PM
Reiem125
Mar 15, 2009 02:31 AM
moeron7
Nov 29, 2007 06:03 PM
