Serious codes
Old Oct 15, 2007 | 06:58 PM
Leifer's Avatar
Default Serious codes
So I went to ACHTuning to pick up an R1, and I told them I wanted an ECU upgrade too, so they ran a diagnostic on my car, which put me in a really really bad mood. See below:
ORIGINAL: Printed VAG-COM results sheet with some fucked up **** on it.
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire detected
P0302 - 35-10 - - - Intermittent
18010 - Power supply terminal 30: voltage too low
P1602 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) sensor B1 S1: NO ACTIVITY
P0134 - 35-10 - - - Intermittent
17536 - Fuel trim; bank 1 (mult): System too lean
P1128 - 35-10 - - - Intermittent
17977 - Cruise control switch (E45): Implausible Signal
P1569 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) sensor B1 S1: Internal resistance too high
P1113 - 35-10 - - - Intermittent
The only thing that I've done so far is throw a new K&N air filter in there (and a stage 3+ FOB).
The DV died on me already, it's gone after I drove it 300 miles (I just got this car two weeks ago)
So what do I have to do to fix these seven deadly sins? I'm thinking the spark plugs and coilpacks are total ****; why the **** else would I have a misfire. Man, I'm pissed.
On the bright side, they said they'd install the new ECU for free. And I got the R1 for $10 cheaper (yes it's brand new, factory-sealed).
So yeah, any suggestions on how to fix them codes? I had them clear the codes and we'll re-scan once I do what I can to fix them.
EDIT: It's a 2000 (therefore a B5) 1.8T.
Old Oct 15, 2007 | 07:21 PM
CRAZYHAWK's Avatar
Default RE: Serious codes
2000 is a B5. Clear the codes and see if they return. Bad sparkplugs,
faultyignitioncoils and vacuum leaks are possible.
Old Oct 15, 2007 | 07:22 PM
Leifer's Avatar
ORIGINAL: CRAZYHAWK
I had them clear the codes; should I rescan after I buy new spark plugs and coilpacks, or before? I'm having them chip the car; so I might as well get new spark plugs and coilpacks anyways, right?
Old Oct 15, 2007 | 07:23 PM
auditech79's Avatar
There all intermittent faults, doesn't mean s***. You probably dis-connected the battery or something or a relay got stuck once. Just erase them and see if any of them come back within 5 days. If they don't it was a fluke.
Old Oct 15, 2007 | 07:26 PM
Leifer's Avatar
ORIGINAL: auditech79
Oh god I love you.
But, what if they do come back? I bought this car two weeks ago, and it had 66K miles on it, so I'm thinking the previous owner could've had some stale codes in it.
Old Oct 15, 2007 | 07:29 PM
khj677turbo's Avatar
If you had real misfire problems, you woulndt need codes to tell you that. Probably just stored over time...
Old Oct 15, 2007 | 07:31 PM
auditech79's Avatar
Fat chance they will. You would have noticed a miss-fire, it takes the computer literally over 50 starts without a problem before the ECM will deem the fault as intermittent. So that means you have driven the car over 50 times and haven't had any problems.
Leifer's Avatar
ORIGINAL: khj677turbo
I can definitely feel my DV giving out. I'm losing *ALOT* of boost from it. ****, it's so loud, I can probably beat cincy in a competition of who's BOV is louder!
Old Oct 15, 2007 | 07:34 PM
Lol well id say no worries, if it was misfiring you would know, your car would run like ***. As does mine right now[:@]
Old Oct 15, 2007 | 07:40 PM
Leifer's Avatar
Phew, yeah. My car runs and handles tighter than a 12 year old
back injury.
So I'll take it back to them tomorrow and have them re-scan it. If they cleared the codes out today, they shouldn't show up as intermittent tomorrow no matter what, right? I'm sure as ******* hell not going to start the car 50+ times between now and tomorrow. I'll start it a grand total of 4 times.
