shell v-power?
Old May 6, 2007 | 11:07 PM
auditech79's Avatar
Default RE: shell v-power?
Yeah and it can damage you cat converter if you drove on it long enough
Old May 6, 2007 | 11:08 PM
auditech79's Avatar
No i would really reccomend either draining the entire tank or completely filling it with high octane gas.
Old May 6, 2007 | 11:10 PM
eurokid's Avatar
6 miles probably*
how do i drain it?
Old May 6, 2007 | 11:12 PM
auditech79's Avatar
The best way would to be removing the rear seat bench and opening the access hole where the fuel pump is and sucking it out with something. You will need some special tools to get the access panel off, or you can use a flathead screwdriver and a hammer if you want.
Old May 6, 2007 | 11:22 PM
eurokid's Avatar
i called down to the shell i went to and turns out that they dont have diesel...?? wow,,interesting..
Old May 6, 2007 | 11:24 PM
auditech79's Avatar
Well back to step 1, check fault codes and post them.
Old May 6, 2007 | 11:32 PM
eurokid's Avatar
P0717 - Input Turbine/Speed Sensor Circ. No Signal
could that be doing it you think?
Old May 6, 2007 | 11:36 PM
  #18
auditech79's Avatar
Man ive never come across that fault before, sounds like the turbo is siezed or no air is getting to the turbo or something? Is the air supply blocked off or is the air filter plugged up? I could be full of **** though.
Post another thread with that fault code.
Old May 6, 2007 | 11:46 PM
  #19
eurokid's Avatar
i think i might get flamed if i post another thread about the same problem?
Old May 6, 2007 | 11:50 PM
  #20
auditech79's Avatar
Well then i would check the airfilter, and maybe take off the airhose to the turbo and try and spin the turbo with you finger, if the turbo doesn't spin maybe it is seized, but i really can't help you with that fault code i haven't come across it and im just kinda guessing.
