Short Block optoins
Old Jan 2, 2008 | 04:35 PM
khj677turbo's Avatar
Default Short Block optoins
Wondering where to look for short blocks, remanufactured would be ideal. Any ideas besides say shokan?
Old Jan 2, 2008 | 04:41 PM
cincyTT's Avatar
I'm make believe
Default RE: Short Block optoins
Buy the built block being sold here. He has a great setup and is asking $3k shipped for it. Drop it in and your ready for w/e turbo you can dream of.
https://www.audiforums.com/m_736847/mpage_1/key_/tm.htm
Old Jan 2, 2008 | 09:06 PM
Cincy, i think thats kind of unrealistic for me. I would love a stock bottom end with forged pistons for security measures, say a gt28rs even if i wouldnt need it, i dont need some random explosion and this whole situation of a new motor to arise. Where should i look for say slightly used bottom ends with new rings etc? Or should i just buy a used one and have it overhauled. Id love any opinion.
Old Jan 2, 2008 | 09:13 PM
cincyTT's Avatar
I'm make believe
just call some shops and see what they can get one for. A used short block should be under $1k
Old Jan 2, 2008 | 09:19 PM
viper9821's Avatar
OK I have to ask a noob question since i've never read about it. Whats the difference between long and short block? If there is a thread I haven't found link me to it and save a few words.
Old Jan 2, 2008 | 09:21 PM
cincyTT's Avatar
I'm make believe
shortblock - w/o head
longblock - w/ head
just dont ask me whats the diff between V8 small and big blocks
Old Jan 2, 2008 | 09:26 PM
viper9821's Avatar
Thanks, I know about those 2 and I wasn't getting them mixed up if you were wondering
Aren't there a few cars in the classifieds being parted with good engines on these forums and audizine also, it's probably worth keeping an eye open. Bore it to 2.0!!
Old Jan 3, 2008 | 12:05 AM
chaos92287's Avatar
whats up now man? didn't you just rebuild the head? y do u need a bottom end now?
Old Jan 3, 2008 | 02:06 PM
Chaos, to be honest i dont know what i need anymore, maybe advil. The car only got worse after changing the head. So i ask how could that be? Timing is right on, valves werent bent when taken out etc etc. rings seemed good along with the cylinder walls. I still have a clunking sound which makes no sense because the head should be perfect, and if it was a valve before then surely the head shop would have told me it was a bent valve. I had 180 compression on all cylinders except number 1 which was at 120, now i have 150 on all and 105 on the first. So is the head worse now? clunking sound is still there. THe list goes on and on, and we are trying to diagnose it without doing a motor swap at this point.
Old Jan 3, 2008 | 03:51 PM
CRAZYHAWK's Avatar
Pour some heavy motor oil in cylinder 1 through
the spark plug hole. Do a compression test. If it
improves the rings are worn.
AudiTurbo
May 18, 2014 09:11 AM
antolin
Jan 6, 2012 05:13 PM
zensane
Apr 10, 2011 07:17 PM
auditt225
Feb 14, 2011 11:52 AM
Mixmastermike
Feb 24, 2010 09:26 AM
