Short Shifter Worth the Time and Money? Is the Installation a hassle?
Old Dec 2, 2007 | 05:39 PM
mschwister12's Avatar
Default Short Shifter Worth the Time and Money? Is the Installation a hassle?
Hey. I currently own a 97 a4 2.8, manual of course. I was just wondering if you thought it was worth the money and time of installation to upgrade the stock shifter to a shorter quicker version? Also is installation a hassle? I was thinking of installing it over christmas break so I could take my time and everything.. So tell me what you think. Thanks.
Old Dec 2, 2007 | 05:40 PM
onepoint8tee's Avatar
Default RE: Short Shifter Worth the Time and Money? Is the Installation a hassle?
Since its one of the only mods you can do for a 12v ([8D]), I say do it! Its not hard to do if you can read instructions and have at least one hand with a minimum of 3 working fingers.
Old Dec 2, 2007 | 05:43 PM
I have the 30 valve.
Old Dec 2, 2007 | 05:46 PM
30v started in 98 in the USA.
Old Dec 2, 2007 | 05:50 PM
i have a 97 2.8l V6 30 valve, 5 per cylinder. I've had my engine apart and individually looked at each valve three on top and two bigger ones underneath them
Old Dec 2, 2007 | 05:52 PM
ORIGINAL: mschwister12
Then your engine was replaced at some time. It is common knowledge that the 30v wasnt introduced until the 98 model yr.
http://www.audiworld.com/model/
Old Dec 2, 2007 | 05:56 PM
You are probably correct.
Old Dec 2, 2007 | 05:57 PM
So lucky you, I guess?
You have reason to believe it was replaced other than that?
Old Dec 2, 2007 | 05:59 PM
qUaTtRoA4's Avatar
ummm, install is frustrating, but not terrible, just take your time and if you have a friend to yell at, it may make things a little easier...
I wouldn't be surprised if you had a 30v 97...check to see if the #s from the car match the motor....
I have the interior of a 98 and the exterior of a 98.5 and I have factory wood trim on a 1.8T....I think audi just uses all of their old stuff till they run out, then they just add whatever they have...
"we're all out of 12V'S!"..."uhhh?, just put in a 30!"
have fun on the install, u gonna go w eBay?
Old Dec 2, 2007 | 06:00 PM
Well in the history there was valve problems and valve medic couldn't fix haha.
