should i chagne my timing belt?
When in doubt, change your timing belt. 60-70k miles is a good place to change your belt. Don't forget to change your water pump, thermostat, tensioners, idle rollers, and maybe think about getting an aftermarket snub mount. Audi's are known to have timing belt breaking problems. When (and its only a matter of time) it does break, it will cost thousands of dollars. So find an independent mechanic and have him change it out, or go to the dealer if you feel like spending a grand.
ORIGINAL: Jestnomen
how much will an independant mechanic usually change for a timing belt replacement, do you think?
imolas...is changing the timing belt something that you can do with the aid of a manual?
ORIGINAL: skibum0019
I just changed mine because it broke but i have to take the head off too to make sure it's good, ITS A PAIN IN THE A$$!!! But a lot better than paying $500 to a private mechanic i asked to do it.
Audiguruforyou
Sep 20, 2011 01:31 AM
Jeffla
Jan 3, 2010 04:43 AM
fritz
Aug 12, 2007 02:55 PM
gTT
May 9, 2007 08:15 PM
