Sick Audi....
Old Oct 2, 2005 | 01:33 PM
nemo2182's Avatar
Default Sick Audi....
Ive recently had my car diag tested and these were the results. The car should be running at 210BHP, but its running ***** at mo, hence getting the test done. Can anyone tell me were to start and whether one error could be having a knock on effect to create the others??I was guna start with Mass air flow sensor?Is there any of these errors that will actually not affect engine performance??Anyways, these are the error codes....
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80) 29-00 - Short to Ground
01262 - Solenoid Valve for Boost Pressure Control (N75) 29-00 - Short to Ground
16486 - Mass Air Flow Sensor (G70): Signal too Low P0102 - 35-00 - -
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction p0135 - 35-00 - -
Any help will be appreciated. I know its pretty much in black and white, but im sure of how to cure the short to ground faults????
Old Oct 2, 2005 | 01:48 PM
david9999's Avatar
Default RE: Sick Audi....
The EVAP code wont cause a problem, but the others will.
Old Oct 2, 2005 | 01:53 PM
nemo2182's Avatar
Any idea where to start?I noticed Euro car parts sell the MAF Sensor for £75. These other short to ground errors etc go over my head! I dont know where either the Lambda sensor or Boost pressure valve are!!
Old Oct 2, 2005 | 02:16 PM
CRAZYHAWK's Avatar
I bought a remanufactured MAF from
www.ecstuning.com
for $85.
Check to see if a local Audi dealer sells them.
Kozzimo55
Jul 24, 2010 11:56 PM
andy7
Mar 12, 2009 11:02 PM
PandaXpress
Apr 13, 2006 12:08 AM
nemo2182
Feb 12, 2006 02:20 AM
easdem
Feb 7, 2005 07:40 PM
