sideways quattro
Old Oct 6, 2007 | 03:57 AM
kemp_travis's Avatar
Default sideways quattro
am i the only one that gets the quattro 1.8t sideways from time to time, and does a few a$$ slides in empty parking lots?..hha
i dont ever hear anything like this everrrr on here...
Old Oct 6, 2007 | 04:00 AM
Audi_Skydiver's Avatar
Default RE: sideways quattro
Thats because Audi's are not made to "a$$ slide"
If you want to drift then get a RWD car. The only time I "drift" is when there is snow on the ground. However, now that I live in Cali that will be hard.
Plus you go through tires to quick.
Josh
Old Oct 6, 2007 | 04:02 AM
well i ordered my rims with tires...so i dont care about these tires...ha...
i was cutting drifting thru an empty parking lot tonight with my buddy(07 gt stang)
Old Oct 6, 2007 | 04:05 AM
Cutting drifting???
josh
Old Oct 6, 2007 | 04:06 AM
cutting little drifts**
Old Oct 6, 2007 | 04:09 AM
Oh, ok.
Josh
Old Oct 6, 2007 | 04:38 AM
Leifer's Avatar
Not like drifting is bad for your rear axel or suspension, either. Did you order those brand-new too?
Old Oct 6, 2007 | 04:40 AM
HAHA [sm=funnypostabove.gif]
Josh
Old Oct 6, 2007 | 08:07 AM
CLX's Avatar
CLX
Zombie Defense Force
ORIGINAL: Leifer
Are you drunk?
Old Oct 6, 2007 | 12:29 PM
Papachristou's Avatar
well i think u should rephrase that to sliding or E braking your car around a parking lot since drifting means you have enough engine power to break all four tires loose causing the car to "drift" around the curve under power... you will need a BT set up with at least 300HP and a stasis rear diff that sends more power to the rear, a coilover setup and RS4 rear sway would help too
even the RS4 in the hands of an experienced drifter will have trouble because of the quattro...
so if a 420hp RS4 with a really good drifter cant do it.. i doubt u were...
