Signal Fuse Problems
Old Oct 8, 2006 | 03:14 PM
DoubleA's Avatar
Default Signal Fuse Problems
Hey i just got an air and fuel ratio gauge. I was just wondering which color the igntion switch is? and the signal fuse is. If anybody knows these colors please tell me. Thanx!
Old Oct 8, 2006 | 03:23 PM
techbod's Avatar
Default RE: Signal Fuse Problems
your last post says it was a mechanical gauge so why the wiring??
Old Oct 8, 2006 | 03:41 PM
DoubleA's Avatar
Nah i messed up its an electrical one...so i need the wiring cable colors. Because I need to wire the green one that comes from the gauge to the O2 sensor which i know where it is just that there are about 5 cables and i dont want to cut each one and test em. So if you know which color the sigal fuse is and the ignition switch colors are that would be PERFECT!
Old Oct 8, 2006 | 03:59 PM
techbod's Avatar
diagram says IT-bl so I assume that white with a blue/black stripe for ignition
Old Oct 8, 2006 | 04:06 PM
DoubleA's Avatar
ohh i c..makes sense...would you maybe know which color the signal wire is? because i have an idea of it but i just wanna make sure. I need that wire because thats the wire ill hook the green up to so it can sense it u know. Thanx
Old Oct 8, 2006 | 04:07 PM
techbod's Avatar
[IMG]local://upfiles/12092/CF60E01D71C94EF0B3E59237395AF690.jpg[/IMG]
Old Oct 8, 2006 | 04:20 PM
techbod's Avatar
#2 hope this helps
[IMG]local://upfiles/12092/48A489A28B9643B4A7CDE04167DD0FE7.jpg[/IMG]
Old Oct 8, 2006 | 04:21 PM
DoubleA's Avatar
ahhh great a wiring diagram nice dude...that helps a lot. Thanx for the help. Its really a pain in the *** to cut all the wires and then test all of them u know. So that helps. Thanx!!
Old Oct 8, 2006 | 04:23 PM
DoubleA's Avatar
that looks like a program? do u have that program or something. Because both are helpfull just that everytime i zoom in i cant really see cuz everything blures. out. If YOU HAVE THE program, tell me the name of it or something. PLease Thanx dude!
Old Oct 8, 2006 | 04:25 PM
techbod's Avatar
mostly useless to me unless im tracing a single fault it tends to give me a head ache
