Slopppyy shifter
Old Sep 30, 2007 | 11:04 PM
kemp_travis's Avatar
Default Slopppyy shifter
my shifter is quite slopy....especially in nuetral.
it shifts fine....but does anyone have any DIY tips for fixing the slop?
Old Sep 30, 2007 | 11:10 PM
Jeff's Avatar
Zombie Defense Force
Default RE: Slopppyy shifter
short throw shifter like the jdm one on zine
Old Oct 1, 2007 | 12:18 AM
kolan67's Avatar
recommend any brands?
Old Oct 1, 2007 | 01:57 AM
Jeff's Avatar
ooops not jdm jhm or something like that
Old Oct 1, 2007 | 10:42 AM
andrewbb89's Avatar
you can even go ebay on the short shifter, its just a piece of metal, i mean how bad can they screw that up
Old Oct 1, 2007 | 11:53 AM
The Russian's Avatar
+1 for e-bay short shifter, got one for my Scion tC last year, $20 and works like a charm, hopefulyl i'll get around to getting one for the audi someime soon... and yeah its the same piece of metal that you would get anywehre else...
Old Oct 1, 2007 | 04:41 PM
ok...but will this stop my slop? and on the ebay shifters ive looked at ..they dont have thay o-ring type of rubber bushing around the pivot ball of the shifter...the same pivot ball that is plastic(stock)....and how big of a b!tch is it to put in?
Old Oct 1, 2007 | 05:05 PM
andrewbb89's Avatar
they are fairly easy to install and it depends what you mean by sloppy like the gear slots are wide and the shifter can move around easily once in gear or do you mean like there is alot movement needed to get from gear to gear
Old Oct 1, 2007 | 11:51 PM
kraylon's Avatar
http://audishifter.com<---Look here
Old Oct 2, 2007 | 01:08 AM
SAudi's Avatar
http://forums.audiworld.com/a4/msgs/1581653.phtml
this is what you need the slop isnt in the shifter itself, its the u-joint shift linkage from the the shifter itself to the tranny, the bushing are rubber, you basically have to pul them out and replace with poly urathane parts.
jibberjive
Feb 24, 2009 12:57 AM
jibberjive
Jan 9, 2009 09:16 AM
jlinaschke
Feb 9, 2007 10:17 PM
jon102034050
Oct 20, 2006 05:55 PM
Cloudy Audi
Nov 12, 2005 02:10 PM
