Smoke
Old Jun 30, 2007 | 06:26 PM
khj677turbo's Avatar
Default Smoke
Well, im in college now for summer session, and i went to my car today, after it was sitting for about 4-5 days i started her up today. I know she was burning some oil, but i always check and fill as needed, which isnt much. But when i gave it some gas to back up, lots of smoke came out the back, and it smelled like oil, this continued when i reved the engine. But not when i just drive. Afer the car was hott, i reved it again, and still smoke, not as bad but it was still there. Am i looking at a bad head gasket, or piston rings?? And cost etc.
Old Jun 30, 2007 | 06:39 PM
JETSPEED333's Avatar
SoCal Crew Member
Default RE: Smoke
black smoke... most likely the rings.
you shouldn't really be burning too much oil up with that engine in the first place.... and since the smoke gets a little better after warm up, that's probably just because after the engine has gotten to norm-opp-temp the pistons have expanded to there norm-opp-temp size.....
i would recomend (if you are not planning on re-building it yourself) to buy a new long block and have that dropped in.
Old Jun 30, 2007 | 06:46 PM
onepoint8tee's Avatar
Default RE: Smoke
Was it black or blue/white smoke?
Old Jun 30, 2007 | 10:53 PM
Default RE: Smoke
Blue white. I was think maybe it was condensation, or just water, w/e but no way. I didnt really notice it too much tonight, but explain why i would want a long block?
Old Jun 30, 2007 | 10:54 PM
Default RE: Smoke
It also still misfires, but if the rings are worn that might cause it yah?
Old Jun 30, 2007 | 11:01 PM
Default RE: Smoke
If it misfires, you need to find out which cylinders are misfiring and rule out bad coil packs, spark plugs, etc before you start talking about bad head gaskets/piston rings/needing a long block(??)
Old Jul 1, 2007 | 01:35 AM
18T's Avatar
18T
Default RE: Smoke
Old Jul 1, 2007 | 12:41 PM
Default RE: Smoke
Just repeating what jetspeed said, what does a long block do for me?
Old Jul 1, 2007 | 06:30 PM
Default RE: Smoke
Anyone?
Old Jul 1, 2007 | 08:10 PM
carMEAD's Avatar
Default RE: Smoke
A long block is a full lower engine assembly,...Block, crank, conrods and pistons, etc. Your mechanicals below the head.
