Smoke from engine
Old Aug 13, 2004 | 08:58 PM
CCGIANTS's Avatar
Default Smoke from engine
Got out of my car today and smelled like plastic burning coming from the left side of my engine, below the intake, or somewhere in that area, I failed to pin point its origin. What could this be, I'm a little concerned about the smelling of plastic, it was pretty intense. Any ideas before I take it in? Thanks!
Old Aug 14, 2004 | 12:08 AM
audiboy1618's Avatar
Default RE: Smoke from engine
Were you on spirited drive and then parked it, Alot of times you will smell the clutch if u glaze it or even sometimes just shifting hard.
Old Aug 14, 2004 | 05:03 AM
CCGIANTS's Avatar
I don't think its the clutch, i know a good clutch burn, but this smells like plastic in a big way. Tonight for example I was driving around doing the speed limit for once, pulled into my driveway, and the smoke came out, not a lot, but enough to be concerned about. Also, what should my dash temp gage be measuring at during a normal drive, mine peaks out at the half way point, is this normal as well?
Old Aug 14, 2004 | 05:35 AM
yeah half way is good
Old Aug 14, 2004 | 11:42 AM
CRAZYHAWK's Avatar
Your water temp. is normal.
Old Aug 14, 2004 | 08:56 PM
Doose's Avatar
Was it just white smoke? Was there smoke soming from under the hood, or just out ot the tailpipe?
Old Aug 14, 2004 | 09:22 PM
CCGIANTS's Avatar
Its only coming out of the hood, can smell it while driving. It seems to be coming from somewhere under the passenger side portion of the engine, somewhere under the intake, and smoking up in-between the engine and the air intake.
Old Aug 14, 2004 | 09:36 PM
Doose's Avatar
What engine do you have? Maybe your valve cover gasket is leaking throwing some oil on hot exhaust.
Old Aug 14, 2004 | 09:40 PM
CCGIANTS's Avatar
I have a 98 2.8 30v tiptronic
Old Aug 14, 2004 | 10:06 PM
Doose's Avatar
Ok. Possible there's a velve cover gasket leak on that side?
