Snake noise... HELP
Old Apr 23, 2007 | 02:12 AM
akoby9's Avatar
Default Snake noise... HELP
Ok... so as of lately I have been hearing this noise from my car... I think its coming from the DV. When I first did the install of the custom intake I got the clearn psshhhh sound. Then just the other day it started to make this snake noise, kind of like the greddy BOV rattle snake thing. I just went under the car and couldn't really see anything that looked loose or that was disconnected.
Also on a side note I saw some oil... I think not sure but whatever part of my engine that is right in the middle of the lower part of my car... like if you looking straigth up in the middle, had some wet stuff on it... Ideas PLEASE!!!
Old Apr 23, 2007 | 02:28 AM
auditech79's Avatar
Default RE: Snake noise... HELP
Check behind the engine and around the coolant resivior area for broken vaccum lines or check valves, when a check valve or vaccum T goes out it can make all kinds of stupid noises.
Old Apr 23, 2007 | 08:13 AM
kraylon's Avatar
vaccum hose are a on going thing with these cars everytime i thing i got all the hoses replaced i find another one that is spit [:@]
Old Apr 23, 2007 | 12:48 PM
akoby9's Avatar
so this morning when driving to work I turned off my music and tried to listen real carefully. I think that its somewhere in the turbo line or something cause when my turbo 'spools' i can just hear it like its sucking wind... it doesn't make that spool sound anymore, or very little. Then when I let off the gas it makes that rattle snake noise. Could someone please direct me to where this 'line' might be or tube whatever please?
Old Apr 24, 2007 | 02:08 PM
akoby9's Avatar
Still need help please
Old Apr 24, 2007 | 02:27 PM
LampyB's Avatar
akoby if you make it to denver...3zero3motorsports(.com) will diagnose your problem for free.
LampyB.
Old Apr 24, 2007 | 02:36 PM
onepoint8tee's Avatar
Sounds like you are describing DV flutter. If your valve is adjustable, you probably either need to increase the tension on the spring, or use a stiffer spring. If its the stock valve or 710N type, it might be shot. Might be a the DV vac line, but if not, theres no reason you sholdnt buy my DV!
Old Apr 24, 2007 | 03:21 PM
96audia4's Avatar
did you check for this?
Old Apr 24, 2007 | 04:21 PM
akoby9's Avatar
thanks onepoint! I guess that would make sense, I thought it was maybe something that was coming apart/loose but I couldn't find anything, guess I'll order that forge007 now!!! and see if that fixes the problem.
ummmm and as for that snake... I HATE snakes soooo freaking bad, btw... that thing would have froze this morning here in steamboat seeing as it snowed!
Old Apr 24, 2007 | 04:22 PM
akoby9's Avatar
also is this going to be really bad if I drive around in it for a week or two like this?
