SO desappointed!!!!
Old Oct 8, 2005 | 10:17 PM
RomeA4's Avatar
Default SO desappointed!!!!
I'm so desapointed, i lowered my B5 by 1.75 front nd 1.5 rear and it's not low at all, I mean it's lower that than stock but not low enought WTF....I still have a 3 inch gap from the tire and the fender...I running on 16" with tire size 205/45/16....Do you guy think that the springs need to break in or it's the way it is because if it is man im buying new springs again. Help
Old Oct 8, 2005 | 10:27 PM
headshok2002's Avatar
Default RE: SO desappointed!!!!
well... what springs did you buy? pictures?
Old Oct 8, 2005 | 10:28 PM
RomeA4's Avatar
I bought the intrax brand
Old Oct 8, 2005 | 11:13 PM
RomeA4's Avatar
Any thoughts about whay it is like that?
Thanks
Old Oct 8, 2005 | 11:57 PM
flyboy's Avatar
I think your tires are to small. You need a taller sidewall. I run 225-50-16 that spec out to the factory 25"
Old Oct 9, 2005 | 12:11 AM
I hope he means he has 205/55/16... the factory size. Otherwise... *slap*
Old Oct 9, 2005 | 12:28 AM
flyboy's Avatar
Yeah, If you go into the diff, tire manufaturing data sheets you can find all the specs on the diff tires. Thats where i ended up with the size for mine.
Old Oct 9, 2005 | 01:15 AM
RomeA4's Avatar
Thanks guys
Old Oct 9, 2005 | 01:16 AM
RomeA4's Avatar
But also what if i get 17 or 18 rims with low profile like 205/35 or 40/ 17 or 18...would it be good?
Thanks
Old Oct 9, 2005 | 01:38 AM
You clearly didnt look up any tire diameters!
For the easiest and closest to stock results:
17's --> 225/45/17
18's --> 225/40/18
