So what if it jumped to 70mm?
Old Jan 21, 2008 | 11:33 PM
anmagro's Avatar
Default So what if it jumped to 70mm?
Hey guys, searched this already...nothin came up.
What if by the use of magic....the throttle body on the 2.8L 30v gained 10-20mm in diameter?
What do you think would happen?
Old Jan 21, 2008 | 11:37 PM
Rhinop21's Avatar
Default RE: So what if it jumped to 70mm?
nothing...
Old Jan 21, 2008 | 11:55 PM
Bondga's Avatar
the world would begin to rotate the other direction and life as we know it would cease to exist!!!!!!
Old Jan 21, 2008 | 11:59 PM
chaos92287's Avatar
cfm would increase the equivalent of a gt35r and you will rape all 1.8T's
Old Jan 22, 2008 | 12:50 AM
Rhinop21's Avatar
^Its true
Old Jan 22, 2008 | 12:53 AM
sean1.8t's Avatar
ORIGINAL: chaos92287
not only 1.8ts.. but all EVO's and Supra's will be running scared from your beastly 2.8 w/70mm throttle body
Old Jan 22, 2008 | 01:00 AM
sean1.8t's Avatar
ok, ok, in all seriousness..
the 2.8 isn't really choking on it's small TB. it breathes just fine for it's displacement and current intake.. FWIW, the 5.7L Hemi uses a 80mm TB and pushes 350BHP.the new 6.4L hemi uses a 90mm TB. stock it pumps out 505bhp out of that.. so no, you don't need a bigger TB unless you go crazy forced induciton.. which your motor can't handle anyways
Old Jan 22, 2008 | 02:25 AM
Jeff's Avatar
Zombie Defense Force
damn sean you look that up or just know that off the top of your head?
Old Jan 22, 2008 | 08:20 AM
anmagro's Avatar
that would be great if he knew it off the top of his head...a true muscle head.
aaaaaaaaannnnnnnyyyyyywwwwwwaaaaaayyyy. i guess from now on throwing in some comedy with the 'magic' thing will be a no-no. creates flames...
any body know how big the stock throttle body is?
Old Jan 22, 2008 | 12:23 PM
Rhinop21's Avatar
Big enough...
