So what are the symptoms of ___ going bad ??
The PA turnpike kicks ***...definitley got it up to 120 driving down to Philly.
I've heard someone on the forum refer to the noise made by failing control arms as "two inflated balloons rubbing together"...or is that CV joint? can't remember.
this DEFINITLY sounds like an out-of-balance wheel..
thats what i had it chalked up to until last week.
i figured since i was getting my summer tires taken off and the snow's mounted and balanced
the problem would go away
but like i said, unless the tire-guy just happened to put the same corner off-balance, i'm thinking it's something else now
good thing it's not noticable at 120+ !!
p.s. ... Jazz, my personal record on the turnpike is 135 ..... whew, thats just about as fast as i think i could handle... car may have had a little more, but my nerves were at their redline...
BRAVO TO BSJ0887 & CRAZYHAWK !!
thanks for your help guys !!
hit the nail right on the head...... wheel bearing was bad
getting it fixed right now.
appriciate the input and the knowledge, it was EXTREMELY helpfull
I just got my rear passenger wheel bearing replaced. The symptoms you described were very similar to mine.
PA Turnpike= Pennsabahn
There's something wrong if you're not doing 80-90mph.
I had the same thing on right front wheel bearing, replacing it took care of it, so far I've had 3 of 4 wheel bearings replaced. All covered under the extended warranty at least.
