Some Questions for people with K04
Old Mar 16, 2005 | 10:53 PM
Fieldy's Avatar
Default Some Questions for people with K04
Well, today I was offered a full-time summer internship. I was thinkin' with going with the APR chip and Bailey DV, but now I realized I might have a pretty chunk of change this summer to spend on my car So, I started thinkin' about the K04 from AWE. I searched about it, but here's some things I still don't get-
1. Is the difference of K04 vs. just APR chip worth the extra $1,300?
2. How much did it cost to install it?
3. Do you need to upgrade anything else like DV to run it reliably?
Any overall opinions would be appreciated. Thanks.
Old Mar 16, 2005 | 11:34 PM
Doose's Avatar
Default RE: Some Questions for people with K04
Fieldy, I can tell you from my experience;
1. There was a huge difference between chip alone and chip plus turbo. Keep in mind I did the chip alone and then added the turbo and everything else at the same time.
2. Three knuckles, about 250 f-bombs and a case and a half of beer.
3. Yes, you should upgrade the DV and also make your exhaust less restrictive.
In retrospect, it would have been a whole lot easier to go at the turbo from the bottom than the top. It's not that big of a deal to remove it from the top, but the oil return line is a huge PITA to reconnect from the top. I didn't go from the bottom because I had nothing to pry tension back into the A/C compressor belt when re-installing it. Air tools would be a huge help, that would have cut the f-bombs in at least half, and saved a lot of skin on my knuckles too. If you want, PM me and I'll give you a list of the parts you'll need (gaskets, banjo bolts, hose clamps, etc.)
Old Mar 17, 2005 | 12:09 AM
audiboy1618's Avatar
Doose is right about the knuckles,my hands looked like i had them caught in the fan.
Old Mar 17, 2005 | 04:09 AM
apg96's Avatar
go here for everything u need to know
Old Mar 17, 2005 | 12:59 PM
clconversion's Avatar
haha you will not regret getting this turbo over just a chip and there are always add on's u can do afteerwards like FMIC bigger files injectors
install I don't know yet (damm bodyshop hurry the hell up ) but I will have air tools available to me when doing this [sm=happy046.gif]
yes u will need to change your DV if you plan on doing this upgrade
Old Mar 17, 2005 | 11:09 PM
Fieldy's Avatar
Thanks a lot for all the help. I'm a total idiot when it comes to hands on stuff with car (or just an idiot in genral) so I would have to get it done at a garage. Thanks for all of the advice.
When you guys talk about gaskets, and all that good stuff to also get... if I was to buy the AWE kit for simplicity's sake, would everything I need be there? Or is AWE not the way to go? (got about 2-3 months to figure this out).
Old Mar 17, 2005 | 11:15 PM
kink's Avatar
the awe kit is good for the k04 turbo, but i have been looking at the pes t-28 turbo package which gets you to 270 hp. Comes with mostly everything but is gonna cost you $3800 IMO i think the t-28 package is better but what do you guys think?
Old Mar 17, 2005 | 11:25 PM
Yes the awe is good, ko4s can make 280hp, and 350tq+, the ko4 makes more torque then the t-28s, its a all torque monster.
Old Mar 17, 2005 | 11:38 PM
black b5's Avatar
wow! a k04 is capable of producing 280 hp?
what additional mods are needed to get those kind of gains?
Old Mar 18, 2005 | 12:13 AM
kink's Avatar
what would the t-28 be able to produce if the k04 can get up to 280? t-28 300+????
