something odd when useing vag
Old Oct 13, 2006 | 06:46 AM
kraylon's Avatar
Default something odd when useing vag
when i use my vag my right rear speaker pops and makes noise the whole time that the vag is pluged in it has only started to do this in the last month before it would make any noise and it didn't matter if the radio was on or off and now if thje radio is on it will not scan it says to shut car off for 30 secs and start over any idea?????
Old Oct 13, 2006 | 06:57 AM
techbod's Avatar
Default RE: something odd when useing vag
is it an after market radio?? if it is you need to disconnect the radio power leads because the original radio is connected to the DLC pin 7 so the dealer can scan the full system, you could damage your laptop/PC
Old Oct 13, 2006 | 07:00 AM
kraylon's Avatar
but my car has had an aftermarket radio in it since i bought it last year and have vaged it probaly 25-30 times and i never had this problem till last month and not it does it every time i vag it but next time i will unplug the radio, what is the DLC Pin 7 i know it is a wire in the radio harness but which on is it?
Old Oct 13, 2006 | 07:05 AM
techbod's Avatar
Default RE: something odd when using vag
well im only quoting Audi, the reason you get this problem is because your radio has a permanent memory live and a switched live so the DLC grounds pin 7 K line to interrogate the ECU and by having and aftermarket unit that pin would short your PC because it would be live + when it should be grounded,
Old Oct 13, 2006 | 07:08 AM
techbod's Avatar
unless you have the correct Audi converter lead for your radio and its DLC compliant??
Old Oct 13, 2006 | 07:09 AM
kraylon's Avatar
i am using a pioneer radio which is probaly not dlc complanint
Old Oct 13, 2006 | 07:14 AM
techbod's Avatar
I can only hazard a guess that what I have said could be the problem even though you have used VAG on it before, the problem is well known in the dealers that's why they wont scan newer cars without the original system in, try disconnecting the radio power supply ( both live leads ) and see if the problem goes away
