spark plugs
Old Nov 19, 2004 | 04:17 AM
thintzen's Avatar
Default spark plugs
can i use bosch platinum4 plugs on my a4 1998?
Old Nov 19, 2004 | 09:24 AM
Jestnomen's Avatar
6th Gear
Default RE: spark plugs
Those are not recommended for Audi's. They will not help performance and i've heard they make for rough idling and just plain suck. NGK's are the recommended brand.
Old Nov 19, 2004 | 04:11 PM
Soley4pres's Avatar
Jestnoman...
what model NGK is recommended for 1.8T a4s?
if I get a chip is this still the spark plug I would use but just gap it different?
thanks
T Pres
Old Nov 19, 2004 | 04:37 PM
Jestnomen's Avatar
6th Gear
found ya an article at audizine
Old Nov 19, 2004 | 06:21 PM
dudley doright's Avatar
I have a 2001 A4 1.8T AWM and currently using PFR6Q. I am still getting some slight misfire at idle but my VAG does not show it. Can someone tell me if they used BKR6E-11 in their A4 with the same engine as mine?
Old Nov 19, 2004 | 06:55 PM
CRAZYHAWK's Avatar
I'm using the same plugs as you, dudley doright, with no problem.
Old Nov 19, 2004 | 07:08 PM
I don't really have a problem. It was just misfiring sometimes at idle, or it seems like a misfire.
Old Nov 19, 2004 | 07:27 PM
clconversion's Avatar
Hey Dudley those PFR6Q plugs are the same as the 101000063aa plugs that we use here they should be working fine in your vehicle but the BKR6E-11 don't even show in my book I'm not sure what those are for
Old Nov 19, 2004 | 07:29 PM
King_D's Avatar
I use denso iridiums but at $60 bucks for four its kinda hard on the wallet. And since the electrode is such a fine point (0.7mm) if you bend it while trying to gap it, you have to buy another plug
Old Nov 20, 2004 | 02:05 AM
Soley4pres's Avatar
Thanks Jestoman for the article.....I appreciate it bro and i ordered the NGKs off of sparkplugs.com
King D....dont quote me on this but with the audi turbo platform we are not suppose to use Denso Iridium or anyother platinum plugs becuase they dont work the way they are suppose to...Ive read alot about these...in fact check out the thread that Jestoman put on his post it talks about it
T Pres
