speakers
well i bought a box wit 2 12" woffers and an amp.. the only thing i know how to wire everything except for the line to the batter how did u guys wire the cable to the battery is there a hole somewhere to put it through or wat?
RE: speakers
also i found out u could run the wires along the door panels so it would be a big help if you guys could help me find a hole in the firewall or if its a good idea to do the door panel
RE: speakers
What year if its a b5 then there is a gromet in the center of the firewall that you can go threw. It will drop down behind thecenter of the dash.
RE: speakers
its a 99 b5 2.8.. but is it hard to get the cable threw that section and do i have to take anything apart that might cause trouble cause i really dont want trouble installing this
RE: speakers
What size is this wire 4-2 maybe even 0 will fit. You will be all good!
RE: speakers
the wires not big and i dont know the guage of wires so that doesnt help but later after work(where i am now) ill check behind the dash
RE: speakers
You got to go threw the engine bay with the wire or you will not see where its at. Once you push a foot or 2 into the dash you can crawl under the dash and pull it down.
RE: speakers
alrit thanks for your help i just need to go check it out and then if i still have questions ill be posting again but until im done work and other stuff i cant check so thanks again
RE: speakers
well after work today i was able to check for an opening and i couldnt find anything. when you meant that it was around the engine bay.. where do u mean do i have to go from underneath or do i have to move something cause i cant find it
RE: speakers
look for black rubber grommets, on the second firewall, behind the battery, pull it away from the metal a little and cram the wire through there for a few feet, then look under the dash with a flash light and look for the wire, and pull it the res of the way through.. then remove kick panels, and pull up sill plates (becareful there is a screw next to the bottom of the back seat with a screw in it) run the wire through there, and tuck it under the carpet.
i have mine ran through the grommit for the hood latch, i had to attatch an old metal antenna to the end of it so i could fish it through.. it was more difficult because its a 0 gauge |
