starting
Ok, today after leaving the mall my car wouldn't start all of a sudden. I decided to push the car and pop the cluth and hence it started. After i turned off the car again it wouldn't start by key. However it would with the autostart. It is not the battery, thats for sure. So what can it be?
RE: starting
Not sure what autostart is.
RE: starting
Have you wiggled your key back and forth in the starter key cylinder? Sounds like you have a problem in there.
RE: starting
found out what had happened........i adjusted my steering wheel and a plug that goes to my alarm system got loose? It looked like a relay that you can unplug. Dont know what it is but i plugged it back in and now its fine.
RE: starting
Glad we could help :D
RE: starting
hehe, I knew that all along. Checking that was my next suggestion. [8D]
