Starting Problem
Old Jul 18, 2007 | 11:55 AM
merlinct7's Avatar
Default Starting Problem
My daughter's '96 2.8 A4Q had a starting problem this AM. Turn the key, all dash lights came on but no solenoid click and no starter turnover. I tried 6 or 7 times and finally it did start and all appears normal. I'm thinking bad ground/loose batt. cables but haven't had time to check it out yet. Anybody else had a similar issue?
Bob
Old Jul 18, 2007 | 12:09 PM
CLX's Avatar
CLX
Zombie Defense Force
Default RE: Starting Problem
Is there a lot of corrosion on the terminals? Clean them, and replace the connections if needed. It sounds like it's just not getting enough amps through.
Old Jul 18, 2007 | 12:17 PM
18T's Avatar
18T
prolly just the batt.
Old Jul 18, 2007 | 12:25 PM
acetrebo's Avatar
Could be bad battery, or starter.
When my starter went, it did the same thing. Nothing. No click, no sound, nothing.
Test battery with voltmeter at terminals. If thats OK, remove belly pan, and test for battery voltage at the starter terminals. (you'll need someone to turn the key for you.)
If you have battery voltage at the starter, then your starter is bad. I replaced DIY for $175, bosch lifetime warranty starter.
Old Jul 18, 2007 | 01:13 PM
merlinct7's Avatar
Thanks, will check out batt. & starter if necessary!
Lourenstien
Oct 30, 2012 07:49 PM
bradwall96
Apr 25, 2011 05:10 PM
PaulA4
Feb 20, 2007 06:55 PM
lhayes
Jun 30, 2006 09:20 AM
PaulA4
Mar 9, 2006 04:30 PM
