starting problems
Old Jun 19, 2009 | 08:05 PM
joe4123's Avatar
Member
Default starting problems
Hey guys could really use some help. My car starts fine when it's cold. However, periodically after I've driven somewhere, stop the car, come back 5 to 15 minutes later and restart it, it won't start. The battery is strong, the engine cranks over fine, but simply doesn't fire. Finally, typically after 10 to 15 minutes and a dozen attempts, it will finally start. When it does start, it does so instantly, there's no sputtering, smoke, or anything unusual. The car acts like nothing was wrong at all. In general the engine runs well, has good power, etc. Also, when all this happens, there are no "check engine" messages.
When I've brought the car to my local shop, of course it starts fine so they don't have any idea what to do. I went to my nearest Audi dealer and they gave me a Technical Bulletin that suggests things including decarbonizing the engine, changing plugs (which I had done recently), replacing the fuel injectors, the thermostat, and the coolant temperature sensor. Some of these don't make sense and some I've done.
Do you have any idea how I can fix this?
Thanks.
Smokin Tubes
Feb 5, 2012 10:11 AM
joe4123
Sep 16, 2009 11:17 PM
james0013
Sep 2, 2008 11:22 AM
katze
Aug 28, 2006 11:09 PM
Limmy711
Sep 15, 2005 02:11 AM
