starting problems
Old May 1, 2006 | 06:54 PM
seventwenty's Avatar
Default starting problems
I have a 98 audi a4. Its been having problems starting for the past month or so. If its cold, it will start right up for the most part. However, if i drive around for a while, get it warm, then turn the car off and then try to go back out and start it up again it gives me problems. it doesnt always do it, but sometimes it just wont start. any ideas at what this could be?
Old May 1, 2006 | 07:05 PM
illridezwannabe's Avatar
Default RE: starting problems
this problem seems to have been reported before. try searching for "start warm"
or try:
https://www.audiforums.com/m_250535/tm.htm
https://www.audiforums.com/m_262324/tm.htm
as a start...
sry i cant be any more helpful, I am a big newbie.
Old May 1, 2006 | 07:54 PM
onepoint8tee's Avatar
could be the engine coolant temp. sensor.. Or reallly bad plugs. Or something else.. But it sounds like an ects to me.
Old May 1, 2006 | 08:33 PM
BadLuckAudi's Avatar
yep sounds like the coolant temp sensor to me too, those little buggers can really **** with your car when they go
Old May 6, 2006 | 11:45 PM
dankhound's Avatar
Does the car even crank when its warm?
Old May 16, 2006 | 08:26 PM
gslippett's Avatar
I am having the same problem with my 03 1.8t . I go to start it after having parked it for about an hour or so and it takes about 3-4 times before it finally stays started...The dealership is clueless..so am I at this point.
Old May 16, 2006 | 08:31 PM
Beer Mod's Avatar
It sounds like coil issues......bad coils work great when they are cold but once they get hot the won't work (if they are infact going out)......
Old Apr 6, 2007 | 05:04 AM
samzo's Avatar
Default Hi there
i have a 1998 audi a4 1.8t. Very same problem will not start sometimes and starts in a few cranks, also the mli/mla light is on with code "PO116" which thnaks to someone has led me to an interpretation : engine coolant sensor or faulty wires ....only two answers. Does anyone know if it is the sensor in my case, becasue under the code (when uploaded, it said also air/fuel module...Thanks
Old Apr 6, 2007 | 07:36 AM
AteUrV8's Avatar
Default RE: Hi there
does it crank???or not do anything at all???
Old Apr 6, 2007 | 07:54 AM
samzo's Avatar
Im not knowledgable in cars, but by saying crank im assuming the revving noise it creates when it tries to grab onto something to start it up, it tries and tries, (rarely happens) . I just turn the igntion off and try again at which point it will start (also give it a bit of gas-helps.)
